I've got a Premiere amp with a shocking problem. Well, OK, more of a tingling problem. There's approx. 9.7vac on the chassis. Can someone list some common causes of AC leakage like this?
AC on chassis
"Premiere"? Don't know the schematic from just that.
If it's a two-wire AC power cord, could be the death cap/switch leaking. Could be the transformer leaking. Could be a stray AC wiring strand brushing the chassis. Could be contamination on wiring or inside a switch leaking, could be a heater winding shorting to chassis, could be any AC wire. Could also be one of the PT secondaries leaking to chassis, as they all have a ground to chassis through signal ground. Could also be a leak inside the PT, although this is unlikelier than other things already listed.
If it's a three-wire AC power cord, there are Big Problems.
The real cure is to go through all the AC wiring. There's really not that much of it. And if it's two-wire, make it three-wire.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
