I need preamp education
  • I need preamp education
    In a 3 tube preamp set up..... V1 ( 1st gain stage ) V3 ( PI ) Exactally what does V2 do and how does it change tone when putting different brands of
    12ax7 in that position. What is V2's importance in the overall scheme of the preamp ? I can't seem to find much info on V2. Thanks for your answers in advance.
    JIm
    JIm
    The first section of V2 is typically a second gain stage and the second section is a driver for the tone stack. V2 tends to be more forgiving than V1 for tube noise. If your amp uses a 12ax7 in V2 I would not suggest any major reduction in gain as it will change the impedance driving the tone stack. What amp are you talking about?
    Chris
    Tubeboy
      My amp is an 18 watt Marshall Clone with an ef86 chanel. Thanks
        The typical tone stack is completely subtractive - it cuts only, no boost. SO after coming through the stack, the signal will be reduced from what it was before the stack. So on many amps the stage after the EQ is to recover the lost level.
          Thanks Guys,
          That is the information I was looking for. It is much appreciated.
