Just got a nice little second hand Behringer BX1200 bass combo and after just one quiet session it developed a serious hum after I plugged in the footswitch and then no sound at all, with the pong of something burned out. Nothing looks melted inside and I have the schematic, although I am much more comfortable with valve stuff, so can anyone help me out please? There are two 3886 chips , should I just replace those and see how I get on? Steve.
Behringer power amp burnout
Maybe. Is there DC on the speaker? That points to failed 3886s, so then I would replace both even if one SEEMS OK.
But you could also have lost a main filter cap. Find the two main power supplies and see if they both have about the same voltage, though at opposite polarities, and that both are free of ripple.
Same with the 15v low voltage supplies.
And you may have lost one of the op amps, usually a TL074. The corner pins on those are outputs, any in the signal path stuck on DC?Education is what you're left with after you have forgotten what you have learned.
Originally posted by J M Fahey View PostI guess it uses those LM3886 in parallel, an idea which scratches me the wrong way, ugh!!
Now if they were bridged, that's something more sensible.
Can you post the schematic to check it?
Thanks.
http://music-electronics-forum.com/t22260/
schematic behringer BX1200, also BX1800 for posterity
Thanks.
Ugh !!
Terrible designs!!
Parallel chipamps are a bad idea, but this implementation is even worse, because each amp has its own feedback network.
Makes matching ultra ultra necessary, and the smallest error sets one chipamp actively shorting the other. Double ugh!!
And the 1800 is not that better, it relies on power Mos providing voltage gain, and there is not local loop, NFB goes end to end "outside" the amp.
Unstable as h*ll.
Well, it's not a moment to redesign, just replace both chipamps and cross your fingers.
And (a lot of) good luck.Juan Manuel Fahey
Originally posted by steve in the uk View PostOne chip shows 42 volts on pins 1 and 5, zero on pin 3. Other shows 42 on pin 1 and. 3, zero on 5.
Pin ! & 5 are tied together on the schematic.
And pin 3 is two small value resistors (R10 & 11) from pin 3 IC #1.
I would check R10 & 11 for opens.
And verify the circuit trace from Pin 4 to 5 on IC #2.
Well I got a pair of power chips but, with so little spare time, I passed it on to another repairer, for him to fit. He just reported back that there are several tracks on the pcb burned through, which is borne out by the pong it made when it died. Says its a considerable job making this good. How likely is it that other components have caused this? Might just get it back and fix it at my leisure
Originally posted by stevekendal View PostWell I got a pair of power chips but, with so little spare time, I passed it on to another repairer, for him to fit. He just reported back that there are several tracks on the pcb burned through, which is borne out by the pong it made when it died. Says its a considerable job making this good. How likely is it that other components have caused this? Might just get it back and fix it at my leisure
You can test and discard (pr confirm) that hypothesis in 5 minutes.
Just disconnect that poor speaker to avoid firther damaging it, and then read +V and -V rails.
Not indicated in the schematic but I guess should show around +/-30V, or a little less.
Highest suspects anyway are still LM3886, which even if new , are made to fight each other because of the stupid design
*Personally**, I'd remove them and components directly linked to them and mount a regular (discrete) power module there, using the same heat sink, if space permits.
Can you post a picture of the power amp and heat sink area so we know what we have there?
Unfortunately I think the PCB with burnt tracks is beyond repair.Juan Manuel Fahey
