Egnater Tweaker 40
  • Egnater Tweaker 40
    Looking for a schematic even if its one of the crippled ones from Egnater of the Tweaker 40. One of my buddies has one and it blew the PT. Ordered a Mercury Magnetics PT because Egnater is impossible to get a hold of for even how to get an OEM replacement. Just want to make sure I'm connecting it correctly before I fire it up.
    Thanks.
    Just replaced the PT in one today. Had a question about the blue wire connection and called MM to verify no connection needed and they confirmed. If you got the connection sheet, wire per instructed for 120v. Don't worry about the voltage selector switch. Just bypass it, or connect the hot side to it withe black wire from the bottom hot side of the pwr switch. The neutral wires go to the lug on the PCB behind the pwr sw.
    If you don't have the connection sheet let me know and I'll post it here.
