Wem Copicat Delay Earthing
  • Wem Copicat Delay Earthing
    Hi guys
    Just wondering if anyone has any experience with Wem copicat delays? The studio I work in has just bought two of them. I had a look inside and the Caps on the power supply (1600uf @ 63v) need replacing as they are bulged.
    The other issue which we are concerned about is the earthing. It's wired for 230volts but the earth wire is not connected to anything. I think the idea is that it earth's through the amplifier being used. I did earth it to the chassis before using but then there is a 50/60Hz hum which is a bit annoying!
    Is there a way to earth these units to get around this problem?
    Here's a link for the schematic
    WEM Copicat Mk4 Schematic
    Regards
    Joe
    Did some more searching and found this site which has all the relevant info if someone else needs it!
    Copicat Spare Parts
