I want to try running the B+ separately from the heaters as an experiment and looking through potential filament transformer purchases, I found a 10A with the secondary described as "0-3.15V5V-6.3V". Can I use the 3.15V tap as a center tap, and run the "0-3.15-6.3V" as "3.15-0-3.15V"? Thanks.
power transformer: okay to use as center tap?
Originally posted by dai h. View PostCan I use the 3.15V tap as a center tap, and run the "0-3.15-6.3V" as "3.15-0-3.15V"? Thanks.
RE
Originally posted by dai h. View PostI want to try running the B+ separately from the heaters as an experiment and looking through potential filament transformer purchases, I found a 10A with the secondary described as "0-3.15V5V-6.3V". Can I use the 3.15V tap as a center tap, and run the "0-3.15-6.3V" as "3.15-0-3.15V"? Thanks.
