Buffered blend pot value and taper
  • Buffered blend pot value and taper
    I'm going to make jfet buffers for the two 4-coil pickups I have on my bass. What taper blend pot should I use to blend the signals? MN or something else? How about value? 50K? I like to use vol and blend instead of two vol pots. What about the vol value?
    Marko, Your options are going to be limited for off the shelf blend pots. MN is the proper designation but in my experience some of them work better than others. Either 25K or 50K Ohms will work fine. EMG, Bartolini, Duncan and Audere in the states would all have what you need. In Europe you might look to MEC, Delano or John East.
