For those on a learning quest
  • For those on a learning quest
    An Auzzie forum drew my attention to this site
    which has a lot of good info to surf and "oodles" of on line calculators! *
    Wasn't sure where to post this - perhaps M.E.F.
    could have a Resource Favorites Links list for helpful sites?
    Electric Charge and Electric Current
    * Preamp Calculators
    Cathode Bypass Capacitor
    Coupling Capacitor
    Bright Boost Capacitor
    Grid Stopper Resistor
    Plate Bypass Capacitor
    Preamp Output Impedance
    Thermal Noise
    Phase Inverter Calculators
    Bass Response
    Long-Tailed-Pair Balance
    Paraphase Inverter Values
    Mixer Calculator
    Common Plate Load Mixer
    Power Amp Calculators
    LTP Negative Feedback
    Overdrive Bias Excursion
    System Design Calculators
    Cathode Follower Output Impedance
    LC Ripple Filters
    RC Ripple Filters
    Wire Capacitance
    Resistor Power Rating
    Tube-Specific Calculators
    12AX7/ECC83 Dual Triode
    12AU7 Dual Triode
    12AY7 Dual Triode
    12AT7/ECC81 Dual Triode
    6SN7/12SN7 Dual Triode
    5751 Dual Triode
    6386 Dual Triode
    I think Music Electronics is exactly where it belongs.
      I haven't read it all yet or checked for "technical accuracy" because I'm not qualified. But I LOVE that they use real amp models and familiar parts to write the example problems instead of battery/generator/other generic parts description to demo the math. I'll check it out more as time permits.
      Justin
