I have an older amp with a two prong cable. I removed the two prong cable and I'm about to install and tree prong cable. I have the green wire going to ground, wire the white and the black coming from the power tranny together. That leaves me a black tranny wire and a black cable wire. I have one on/off switch and a fuse terminal to connect to. So with the remaining wires do I jump the switch and the center tab of the fuse together and one black wire from tranny to end of fuse and the other black from cord to the on/off jack?
hooking up a 3 wire power cabl
