Output line for hooking the 2nd speaker to Pyle Pro PPHP 1098A
  • Output line for hooking the 2nd speaker to Pyle Pro PPHP 1098A
    What/where is the speaker output of the Pyle Pro PPHP 1098A to drive the PPHP 1093 speaker ??
    The speaker has 2 strange looking 2 pin i/o jacks, and also 2, 1/4" jacks on the back.... The powered side does not seem to have an output to drive it that I can see.
    I have searched the user manual and found no reference for attaching the other speaker to system.
    Thanks, CW
    Who told you this is possible? The 1098A is powered, the 1093 is not. I don't see any indication that the 1098A should be able to drive a second (external) speaker cabinet.
      Trying to help out a musician friend.
      He was given these items by someone used, and may have assumed they were meant to be used as a pair.
      You may be 100% correct as there is certainly no output capable of driving an additional speaker.
      Thank you.
        From what I can tell, they are sold as individual units. You would want a pair of 1098A's, or a pair of 1093's with an external power amp. Maybe whoever gave them to your friend had a pair of each and got them mixed up?
        Anyway, a power amp will be required to drive the 1093.
          Thank you all for the help, much appreciated.
          CW
