Suggestion on reall preamp pedal for distorted solo
  • Suggestion on reall preamp pedal for distorted solo
    Hi guys,
    Hi , hope all are fine .
    Finally i bought tech 21 blonde BY GOD'S GRACE. It is actually a replacement of my behringer GDI21 (because i don't like the sound from GDI21) But one thing i noticed that behringer GDI21 directly into mixer gives more volume boost and does real preamp, but it sounds really bad , especially in clean setting , it actually increases my guitar signal and increases the volume, so no need to keep full volume in mixer even only 3 point volume in mixer and it will sound equal to keyboard.
    But in Tech 21 blonde i have to keep full volume in guitar and also in mixer to get sound equal to keyboard that too if i increase driver nob beyond 12 0 clock position then it is giving peak sound . I don't know why ?
    Is this because tech 21 blonde pedal does not have xlr out and they say it have low z out put or our mixer is digital and this pedal is analog ? So do i have to buy one DI box to make sound clear, balanced and increased in volume with out peak sound ? if yes , shall i buy TECH NYC para driver DI ? or shall i buy a 1/4 to xlr connector alone ?
    Even though if Xlr out of blonde won't or will not increase the sound volume .
    Then please suggest me one good distortion with volume boost mainly for solo and it should give a sharper and warmth sound with delay and small reverb in it.
    Thanks in advance
