Yamaha YPG-625 keyboard and MIDI
  • Yamaha YPG-625 keyboard and MIDI
    Recently worked on a Yamaha YPG-625s DC jack for a friend, He was asking me about needing a MIDI keyboard and I noticed the Yamaha piano says MIDI on the sticker....
    I know nothing about MIDI, nor can I tell much from the user manual or any web searching that I have done.
    Can anyone provide me with any info ??
    Is this a MIDI keyboard ?? The manual talks about a driver CD but I just don't know anything about any of it.
    Thanks, CW
    The Yamaha YPG-625 has MIDI capabilities.
    It is not a stand alone Midi keyboard as it can also be used as a standard synthesizer/ keyboard.
    The answer to your question on what is Midi & how does it work is a tall order.
    I would suggest that you do some basic research on Google.
    Here is one: MIDI Basics, Part 1
      Here is link direct from the Midi Manufacturers Association.
      MIDI Tutorials
      It includes the history of Midi, an introduction & the technologies used.
        A keyboard or synthesizer generally makes sound. Consumer items often have speakers built in,a pro synth would not. A pro synth would have audio outputs you feed to an amplifier. If the thing ONLY makes MIDI, and no sounds of its own, we would generally call that a MIDI "Controller."
        MIDI is a communication protocol so units can talk to each other. It uses a DIN connector (5-pin 180 degree). If you see MIDI connectors on a unit, then it is MIDI capable. Three flavors: IN, OUT, and THRU. THRU simply sends whatever appears at the IN jack back on out, so you can daisy chain. IN and OUT ought to be self-explanatory. Some few units have only IN or only OUT.
        In our shop we used to have a large box for trash. I mounted some MIDI jacks on it. When someone asked, we could tell them, "Garbage in, garbage out."
          Thanks for the links and all the info provided.
          Best I can tell this Yamaha does not have MIDI jacks.... only USB.
            According to the Yamaha web site for this product it has USB MIDI for computer interface. As I read that it means the unit makes MIDI signals, but only sends them out the USB, so a computer with a MIDI card in it would be needed to MIDI to other gear. Or some other USB to MIDI device.
              Thanks again for the info.
              I will do some more checking for him.
              Craig W
