Anyone have a schematic for a Egnater Renegade. Thanks -------------OMguy
Egnater Renegade
Hi Jazz, Thank you for the drawing !!! The amp quit while they were playing and smelled hot and was shut off. I tested the four output tubes and one of the EL34's showed shorted on my Sencore TC162. The 800ma fuse to the EL34's was open and the 3A main fuse was blown. I pulled (and marked) all the power transformer secondary wires, replaced the 3A main fuse, and brought power up through my B&K 1655. While monitoring the two red secondary wires (QC19 and QC20) I brought power up and the two red wires showed 750VAC (no load) near line voltage. I just happened to be home today and this is all I have done to it so far!
Thank you again, it makes things a lot easier with the drawing. --------------------OMguy
Originally posted by Jazz P Bass View PostWhat is wrong with it?
I have one sitting here waiting for a power transformer (blows the main fuse with no tubes installed)
Originally posted by Enzo View PostI think I will start including a Chinese character or two on my schematics from now on.
had a couple Chinese symbols tatooed on arm and neck, maybe he thought they would bring him luck, you should do the same
by the way, he lost, there's people saying the chinese characters were actually written wrong, so as to bring him bad luck.Juan Manuel Fahey
No tattoos on this boy, never will be.
I think I would put something like the symbol for "eggplant" or maybe "motor oil" on a drawing. See how many people would actually find out it was nonsense, and how many would decide they knew it was a Chinese circuit and it sucked therefore. I like leaving subtle snares around to see who gets caught.Education is what you're left with after you have forgotten what you have learned.
Hi, Guys,I have some problem of my Egnater Renegade, hope someone can help me:
I can not hear the different between 6L6 and EL34 tube mix mode, is it broken? In the middle position of the mix pot, the sound is louder. now I wanna skip the "tube mix" unit of Renegade,just let it work on mix together position, how to wire it? If it is easy to do, anybody can draw the sketch or scheme for me? Is it can work like I draw:
And I wanna skip the "65/18 w switch" function too , the switch have not any effect...both side make the sound same. I even don't know my amp is on 65w or 18w mode now. so I just want it work on 65w only, can I just make the Optocoupler (U1 U2 H11F1) short circuit? or let it open circuit ?
Thank you very much!
Originally posted by fishboya View PostI can not hear the different between 6L6 and EL34 tube mix mode, is it broken? In the middle position of the mix pot, the sound is louder.This isn't the future I signed up for.
I have replaced the voltage follower transistor in one of these before... as well as a bulging 10000uf mains cap.
Now I have it back in the shop a year or so later with a blown PT. Yes they sure did make these a pain to work on in regards to getting the PSU board out!
Guess this is the same schematic Jazz posted.Attached Files
Originally posted by lowell View PostI have replaced the voltage follower transistor in one of these before... as well as a bulging 10000uf mains cap.
Plenty of wiring for a pcb! Especially with PCB tube sockets too!
Is there any secrets or funny stuff to lookout for when it comes time to button up and dress all these wires? Like any nasty stray capacitance or induced noise, oscillations ect???
I also just got one on my bench that the previous tech had replaced the P-Xfmr with a Mercury Magnetics. It is now back blowing fuses and now I am repairing a 10uF cap and 470k resistor.(iirc)
Same schematic...
Anyways been awhile since I haunted these forums. Glad to see ya all!
Brian Southbound SuarezPhineus J. Whoopy, you are the greatest! May just get one more peek at that three dimensional blackboard please?
