I've got a winding machine that uses an AC universal motor, the problem is it runs at 4x the speed I'd like. Will reducing the voltage to the motor reduce it's speed? The winder has 4 electronically controlled speeds. I get a 100-120v reading with the motor running at all speeds.
Reducing motor speed - how?
They're probably chopping the voltage at varying duty cycles. The supply voltage is 100-120V, but the motor sees that as the duty cycle times the voltage. You can do much the same thing with a cheap router speed control from Harbor Freight.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Originally posted by dpm View PostBy the looks of things this winder uses an electromagnetic brake. Pretty cool. I can't believe I missed this the first time I looked inside
BTW, you want to use the speed control on just the motor, not the whole winder, since it has other circuitry.
Also since the winder has programable speed settings, you are going to figure out how to rewire it. Obviously it already had some kind of speed control. By passing the built in circuitry, and you will loose the soft start and ability to have the winder stop at a count. I doubt you can put one motor speed control after another.
Your best bet is to make a belt and pulley setup external to the winder, and attached to the arbor, to slow the speed down.
I have one of those router speed controls from Harbor Freight, and they work great on routers. I don't think that will work on this unit.
I'll trade you my Schatten winder!It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Yeah, the big thing on the left.
Agreed about simply getting a bigger pulley and belt. It's already using a pulley system. Can't seem to find the right size... though it would interfere with the position of the power switch and footswitch socket (which could be moved). 'Spose I could just make a pulley.Last edited by dpm; 07-29-2007, 01:37 AM.
I'm thinking about buying one of these myself - is there any other real issues with these machines, besides the speed problem? I had no idea these were so advanced.
Ken
Originally posted by ken View PostI'm thinking about buying one of these myself - is there any other real issues with these machines, besides the speed problem? I had no idea these were so advanced.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Yeah, ebay from Hong Kong. Takes under 3 days to get to you, it's crazy.
It's actually a really solid unit, I'm quite impressed. There's no play in the shaft or any problems like that, smooth rotation, I think it was a good buy.
I came across model tugboat motors with modular stepdown gears that appear to have the same size shaft. Checking into that option too.
