Results 1 to 9 of 9
Thread: Peavey JSX schematic loaded with info!
    Old Timer tedmich's Avatar
    Apr 2008
    Sonoma CA
    3,161
    Received: 24/0
    Given: 38/2
    I was looking at my JSX schematic to figure out where Peavey decided to put the (superior) NP0 vs crappy X5R/X7R ceramic caps and 1% MF versus 5% CF (in all of the preamp plate resistors) and I found that a simple PDF program (Foxit) reveals a lot of extra data on each component.
    Just left click and the attributes come up.
    The NPO seem to have the same cost (0.02) as the X7R, but 100k 1% MF plate resistor R11 cost 0.0049 and the nearby crappy 100k 5% CF R23 cost less than half (0.0021)
    Those relays cost almost a buck but the 12AX7 costs only 0.58 (maybe per section?) The big old Illinois PS cap (680uF/350v) only costs at 3.24!
    the joys of bulk purchase!
    The old XXX while pretty much identical, uses MF only in the first two plate resistors, while the JSX has them in all 6, and the JSX has NP0 in most of the tone stacks.
    Senior Member Joe L's Avatar
    Jun 2006
    Louisiana
    163
    Received: 1/0
    Very cool! I use Foxit but don't have a copy of that schematic. Do you have a link or can you post it?
    Never mind. I looked at the bottom of the screen here and found the one you must be looking at.
    ..Joe L
    Apr 2008
    Sonoma CA
    3,161
    Received: 24/0
    Given: 38/2
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,209
    Received: 277/1
    My plain old Adobe Reader does that. All those parts that have a yellow surround have the data. I left click on the part, and select attributes, and all that comes up.
    New Member
    Jun 2018
    1
    Quote Originally Posted by tedmich View Post
    Hi, came across this old thread and hoping somebody can help me to identify the noisy caps to replace in the JSX 212 Combo to reduce the baseline hiss. I think it's these but need some guidance, also what to replace them with.
    Thanks,
    BillyClick image for larger version.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,209
    Received: 249/4
    Given: 261/4
    Sorry Billy but:
    a) capacitors are not noise generators
    b) those black dots you surrounded are not capacitors anyway.
    Dec 2008
    Wernersville, PA
    12,251
    Received: 40/0
    Given: 15/0
    High gain preamp in the JSX.
    Grab a pile of 12AX7 tubes & put the quietest one in V1.
    30,209
    Received: 277/1
    The black dots represent wires from the main board over to the "noise gate" control.
    "HW4" = hard wire #4
    Jun 2006
    Louisiana
    163
    Received: 1/0
    High impedance input gain stages are great for gain, but terrible for noise. First, research the signal and ground paths used by the early high gain designs such as Soldano's SLO. Try using Silver Mica Caps and MF resistors to see if it makes a difference but be obsessive about the ground paths. Shield everything you can to start with then remove the shielding a stage at a time to find what works to make a quiet amp.
    ..Joe L
    1 Not allowed! Not allowed!
    ..Joe L
  1. Peavey JSX amp
    By bsco in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-09-2014, 09:30 PM
  2. Peavey JSX Please Help!
    By itguy88 in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-09-2014, 01:56 PM
  3. Peavey JSX problem
    By wcb2 in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-16-2014, 02:32 AM
  4. Peavey JSX Schematic Needed
    By AtomicMassUnit in forum Schematic Requests
    Last Post: 04-18-2013, 05:06 PM
  5. Biasing Peavey JSX
    By Doug in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-06-2008, 08:13 AM
