Hello
I am working on a Peavey 260D that hums on startup. It doesn't blow fuses. It also has 8VDC across the output jack. I removed the T03 power resistors to test them, which are (4) NPN's marked 67376 and they all test good. I have filter caps on order.
The transformers two legs (+/-15 and +/- 42V) test fine.
I am curious about a couple things - see picture
What is the large device between the power resistors with the twisted black wires attached?
What is the small diode- looking device that goes from the circuit board to the metal heat sink that the T03's are attached to?
I tested the sandstone resistors. They're big (10W) but small value (.33 and .1 ohms). They all test more than 100% over their marked values...should I replace them?
Finally, how else to proceed with troubleshooting after replacing the electrolytics?
Thanks in advance!
Thanks in advance!
