I got a DS-1 from a friend and when he gave it to me he said that it had a huge problem. He told me that whenever he connects it (with a new battery and connected/disconnected fron A/C adapter) the DS-1 nullifies the sound. I tried it myself and happened the same thing. There was only my amps light hum and an IMMENSELY muted sound (that was the guitar playing). Why is that happening on this pedal and if you know, how could I fix it?
Problem with Boss DS-1 when connected
Originally posted by jalvhe View PostI got a DS-1 from a friend and when he gave it to me he said that it had a huge problem. He told me that whenever he connects it (with a new battery and connected/disconnected fron A/C adapter) the DS-1 nullifies the sound. I tried it myself and happened the same thing. There was only my amps light hum and an IMMENSELY muted sound (that was the guitar playing). Why is that happening on this pedal and if you know, how could I fix it?
Boss DS-1 Schematic
As much as I or anyone would love to tell you that The Problem lies in a faulty component # XYZ, that ain't going to happen.
At the very least, you need to take a few voltage readings to see if any are off.
Sending a signal through the circuit & seeing where it fails is also an accepted troubleshooting technique.
I have attached the schematic, if that will help.Attached Files
Can you give us an indication of your technical skills and what tools you have?
You need to be able to follow the signal path through the schematic and relate this to the actual circuit in front of you. If you can do this, then a simple audio probe will enable you to trace the signal through.
There are components you can eliminate; the signal path is buffered when the effect is bypassed, so the path through Q1, C2, Q8 are fine, as well as C13, Q3 onwards.
It's the 'middle bit' that I'd be looking at first, to check if the signal gets in and out of the op-amp.
