I'm guessing most have seen this many times, but I thought I'd pass this along anyway. I was rewinding a '63 Strat neck p/u the other day and found it interesting how the original lacquering had been applied back in the day. It looks like the bobbin was at the eyelet area and dipped in lacquer just enough to cover the magnets. I am assuming it was lacquer. It is more obvious in the pic of the bottom, but you can see it on the top flatwork as well. I guess the thought in the day was specifically to protect the magnets from elements that would cause corrosion. No addressing whether it would be a positive to seal the flatwork completely as well.
Lacquering Process (back in the day. . .)
Take Care,
Jim. . .
VA3DEF
____________________________________________________
In the immortal words of Dr. Johnny Fever, “When everyone is out to get you, paranoid is just good thinking.”Tags: None
Here's an old thread that discusses it Jim.http://music-electronics-forum.com/t2530/
On mine I tape the eyelets, and dip them in waterbased polyurethane. I think dipping is better than spraying because the penetration is better. Originally it was used to hold the coilforms together, and to insulate the magnets.
Thanks for sharing Jim!
I'm curious about the circular impression on the bottom of that bobbin, I'm going to guess left there from the mounting fixture? I haven't had any of these in hand, but haven't noticed that before on photos I've seen. Could you tell if it was machine or hand wound?Bobby, www.TysonTone.com
Could you tell if it was machine or hand wound?Take Care,
Jim. . .
VA3DEF
Originally posted by jonson View PostI think Beef is talking about the large round impression covering the 2 centre magnets Jim. I not see that before.Take Care,
Jim. . .
VA3DEF
Originally posted by kayakerca View PostI guess the thought in the day was specifically to protect the magnets from elements that would cause corrosion.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David Schwab View PostAnd it clearly failed. So do the owner a favor and tape the magnets. Or it will fail again in 50 years.Take Care,
Jim. . .
VA3DEF
Originally posted by kayakerca View PostI'm guessing most have seen this many times, but I thought I'd pass this along anyway. I was rewinding a '63 Strat neck p/u the other day and found it interesting how the original lacquering had been applied back in the day. It looks like the bobbin was at the eyelet area and dipped in lacquer just enough to cover the magnets. I am assuming it was lacquer. It is more obvious in the pic of the bottom, but you can see it on the top flatwork as well. I guess the thought in the day was specifically to protect the magnets from elements that would cause corrosion. No addressing whether it would be a positive to seal the flatwork completely as well.
[ATTACH=CONFIG]30161[/ATTACH][ATTACH=CONFIG]30162[/ATTACH]
I've seen this many times. In fact, I just looked at some of my older Fender pickups that I use as a reference and have a Grey Bottom Mustang pickup that is dipped almost identically to your picture. However, I also have another Grey Bottom Strat, from the same era, that was completely immersed. To be honest, I've never tried to see a pattern or cared much about it in the past...I'll study them more for this as they come into the shop.
As to "why" we sometimes see the line as shown in the picture, my guess is that it might be the preference of certain factory workers to leave the eyelets "lacquer free" for easier soldering. Or, it may be accidental that they just weren't dipped as deep in the lacquer due to a rushing or careless worker. We'll have to study this more to see if we see a pattern. We all have seen a lot of inconsistencies from the 50s, 60s & 70s.
I've always thought that they were dipped in lacquer for two reasons:
1) To insulate the magnets
2) To solidify the coil form
My belief and experience is that spraying them does not solidify the coil form as well as dipping them. I also generally tape my "F" style pickups as well.
Good catch and thanks for the post.
Jim=============================================
Keep Winding...Keep Playing!!!
Jim
