Flat Pickups!
  • Flat Pickups!
    I read the thread in the main area about a particular brand of flat pickup.
    Thought maybe that would make a neat project for the B/H Forum.
    I have a few ideas that might work for a flat sidewinder pickup.
    Looks like the trick would be to wind the coils around some alnico or ceramic flat magnets.
    2 flat coils wound around flat magnets with a short blade in the middle.
    I like the idea of building in into a pickup ring.
    Post your ideas here
    I'll start measuring pickup rings and magnets, and see what would work.
    T
    I think your idea will work, but if I were doing it (and I might some day) I'd stick closer to my guesstimate of the original design:
    Cut a rectangle of 16 GA carbon steel (dimensions for different models are listed on the site);
    Drill 6 holes down the middle to hold 6 neo mags (or try making the pup a bit taller, with 7 magnets aligned between the strings);
    Populate with 1/16" tall neo discs;
    Wrap with cellophane tape;
    Slide on rubber rings to act as end flanges (not sure of source... HW store O-rings?);
    Wind coils onto steel core (How? Not sure- need winder with a tailstock, custom faceplates...);
    Wrap with cellophane tape.
    For details such as hookup wire connection, pickup frame, pickup cover, optional pickup ring:
    Peruse photos on the site- steal those too!
    EDIT:
    Thinking about it a little bit- I'm guessing your pups would be easier to assemble with off-the-shelf parts, but probably not as "flat" as the originals. What are the thinnest alnico or ceramic magnets available? The "brand" bare neck pup is 5mm (.197") thick- and remember, that's with the coil wrapped around the core. I guess it depends how thin you need the pickup to be. In my case, I'd be trying to make a surface-mount neck pup for an archtop with very little clearance between the body and strings.
    EDIT 2:
    Scratch the holes through the core; just stick a row of discs onto its surface (might need something to keep them in place).
    Maybe two rows (front and back) with same magnetic pole facing inward.
    DON'T FEED THE TROLLS!
      On the pickup ring, I was going to use a PAF type pickup ring.
      I can make it all smaller, I think if I wind it over magnets, and keep it to the size of a PAF Cover, but thinner?
      Parts will be easily excessible.
      So Lets make several designs.
      Since I have tons of alnico, and Ceramic magnets, and no NEOs?
      I'm going to stick to parts I have available, probably Ceramic magnets.
      Anyone else want to jump in and try one?
      On the wiring, I will probably do the wiring at the end of the PAF pickup ring.
      Haven't got to it today. Busy planting Clover Patches for the Critters, on the Mini-Farm.
      T
        Everyone is welcome to give this project a shot!
        If you do please report back.
        I put my participation on hold!
        These Reasons are strictly IMO, IME!
        1. You end up with a compromise pickup at best!
        2. It would only be useful on existing non pickup guitars.
        3. If you make one, what becomes of the lead-in wire, and how do you get it to the pots?
        4. It's not that hard to rout a solid body guitar, and use a Real modern designed guitar pickup.
        5 On Flat-tops, IMO it makes more sense to use a Sound-Hole Pickup.
