I have one Dearmond Guitar Mike pickup that doesn't give any dc-resistance reading for the coil but it works. Have you had any similar situations that your pickup works but you can't measure the resistance of the coil? I wonder if it's possible for the pickup to work trough the stray capacitance between the wires.
Pickup works but no dc-resistance reading
Got once a short cut in a coil, making it behave like a capacitor in series with the other coil. No DCR reading but a bright dry tone, reminding a Rickenbacker pickups with its cap in series.
Don Mare (pickup winder) explains something similar about the bridge PU of Roy Buchanan's Telecaster nicknamed Nancy.
Originally posted by Tomi Kettunen View PostI have one Dearmond Guitar Mike pickup that doesn't give any dc-resistance reading for the coil but it works. Have you had any similar situations that your pickup works but you can't measure the resistance of the coil? I wonder if it's possible for the pickup to work trough the stray capacitance between the wires.
Originally posted by Mark Hammer View PostDo not discount the possibility of the solder joint on the pickup having so much tarnish that the meter leads aren't making contact. That's happened to me many times.
Cheers
Andrew
I agree with DK.
If it is anything as hard as the Monkey on the stick, I would send it to the appropriate winder.
Such as Sonny W. Comes to mind!
http://music-electronics-forum.com/users/7495/"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
