im replacing the reverb tank in a crate gx212 amp, it was disconnected when i got the amp and im wondering which wire was the input (red RCA or gray RCA)
crate gx212
Is anyone familiar with the foot switch wiring for this amp is? i believe the reverb foot switch is just a mono 1/4" wired to on off switch, then distortion 1 and distortion 2 are probably wired to a stereo 1/4" jack with the sleeve being common between two switches and tip to one switch and the ring to other switch ? right or wrong?
