hey guys, ive got a peavey special 130 that just kind of fell in my lap thats not powering on. No sort of indication of anything going on. the fuses LOOK fine and nothing else is visually jumping out at me, you guys have any suggestions as to where i might start other than the fuses for finding the problem on this thing. on a side note, it has been setting for quite awhile in a shed prior to me having it.
Peavey Special 130 not powering on
i haven't put a meter on anything as of yet because all my tools are in shop and i am in house tonight but from what i can see there is power coming from the wall and when i turn on switch you can feel the chassis vibrate at a low frequency, not audible though. whether or not im getting correct voltage and what not is to be discovered, in which i will do tomorrow.
Originally posted by jpfx88 View Posti haven't put a meter on anything as of yet because all my tools are in shop and i am in house tonight but from what i can see there is power coming from the wall and when i turn on switch you can feel the chassis vibrate at a low frequency, not audible though. whether or not im getting correct voltage and what not is to be discovered, in which i will do tomorrow.
In the ac wiring, check the ac switch, the thermal cutoff switch, the fuse, and the inrush limiter. If the amp is actually powering up but the front panel leds are not lighting up then the two fuses for the 16 volt supplies should be checked.
So i checked all the fuses with my multimeter and they all checked out, but still no juice. I scratched my head for sec then removed them all and scraped the sockets out and cleaned the fuses, put it all back and boom, it powered on. Now I just got to clean all the pots and get the reverb working
