I built smaller, under-wound "Wide Range Humbucker"
I'm not trying to replicate a Fender WRH in the slightest. I've never heard one, so I couldn't even if I wanted to. My goal has been to come up with a pickup that sounds similar to a strat neck pickup (one of my favorites), but cancels hum and fits in a humbucker routing. Everything beyond that is experimental and hopefully some pleasant discoveries.
Honestly, with half of the magnets pulled on each bobbin, it sounds FAR closer to a strat neck pickup than I expected. I'm very happy with the result and currently building a couple more. I'm going to try something a bit different with the bridge pickup, using A4 rods on the bridge side bobbin. The worst thing that happens is I don't like it and try again! :-)
Originally posted by John_H View PostNice work. Have You tried wiring the coils parallel?
Originally posted by Bradley Perry View PostI have not. I wound it lower with the intention of using series only. If wired in parallel it would would have a really low output and, I haven't check the math, but the resonance frequency would probably be too high to hear prominently through a guitar up.
i just wound a humbucking pickup i designed with 43wire with around 10000 turns and a whopping a5 magnet (different design to std humbucker), and you would swear it was a single coil. all reason and measurements would tell you that it would be dark and muddy, but it is bright and chimes just like a singleLast edited by mr fab; 02-21-2015, 07:41 AM.
Cool! What are the specs on this one, then?
I'll ask again (maybe for the engineers to answer): what's going on with the magnetic aperture/profile that allows this 3x3 design to sound like a single coil? What makes this different than one coil having all six screws and the other coil empty? Could it be done with screws every-other string (one coil odd and the other even)? Could a P-ish bass pickup be built similarly?
When you only have one magnetic pole per string the pickup will not pick up double signals, change polarity wise and still have a bit of top en cancelled (very simplified explanation). The pikcup will only "sense" one single part of the string, hence making it very similar to a SC. However the two colts make it humbucking.
There are suppliers (I will not mention GFS) that sell a standard HB with two rows of screw poles, no slugs and the poles configures 3+3 as a valid substitute for a WRHB. They have a distinctively more SC-ish sound although they are nowhere close to a real vintage WRHB
Originally posted by Jason Rodgers View PostCool! What are the specs on this one, then?
The steel in the coil affects the sensitivity to magnetic fields; therefore keep it the same in both for best hum cancelation.
There is a test you can do. Expose a hum bucker to a strong magnetic hum source. Listen. Remove the screws one at a time. You should hear the hum increase as each screw comes out. (Obviously electrostatic hum must be small for the effect to be noticeable, so use a careful set up.)
This test upsets some people. The long process that resulted in my removal from the Musical Instrument Makers Forum started when I described this test, and the head of the electronics discussion there disagreed. I, of course, did not back down.
With the 3 & 3 threaded magnet setup, it would be similar electrically to a P-Bass Pickup set.
The difference would be the guitar pickup uses two long bobbins, the P-Bass two short ones.
Both only one sensing magnet per string.
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Originally posted by Bradley Perry View PostI'm not trying to replicate a Fender WRH in the slightest. I've never heard one, so I couldn't even if I wanted to. My goal has been to come up with a pickup that sounds similar to a strat neck pickup (one of my favorites), but cancels hum and fits in a humbucker routing. Everything beyond that is experimental and hopefully some pleasant discoveries.
The poles on this one would just be seeing the the string in different places. I've never tried this, so I have no idea how much different it would be than just pulling the screws out of a regular HB.
Looks pretty cool though.
Inductance: 2.36K
Capacitance: Tough to measure with what gear I have, but through my meter it reads almost identical to my Fender American standard Strat neck pickup compared to the value I get through some PAF style humbuckers I tested.
The coil on with the treble pole pieces is slightly higher wound than the lower poled bobbin.
I also have larger screws holding the baseplate to the bobbins to increase inductance without increasing resistance or capacitance...because I'm going more for a strat neck pickup style of sound.
There is also a high iron content steel bar where the typical humbucker bar magnet would be. This, also, is to increase inductance.
It looks like a full range, but it most definitely is not one!
Originally posted by big_teee View PostWith the 3 & 3 threaded magnet setup, it would be similar electrically to a P-Bass Pickup set.
T
Hey Brad:
Where do you get the cover and baseplate for this last one you made?
Also by using the 3-3, you save 6 of the high dollar threaded pole pieces.
TLast edited by big_teee; 02-26-2015, 07:42 PM."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Originally posted by big_teee View PostWhere do you get the cover and baseplate for this last on you made?
The cover is from Philadelphia Luther Supply. They are the only place I found with 3+3 covers, and they have a good selection of finishes. Its a good thing, because I didn't want to have to find tools and spend the time drilling holes myself. Only in 49.2mm though.
Both are 49.2mm spacing.
Originally posted by big_teee View PostAlso by using the 3-3, you save 6 of the high dollar threaded pole pieces.
