Hi i am new to this forum,i am wondering if there is anyone out there who is familiar with the "fender twin red knob amp " ,I have recently got it to restore ,i am not an electronics expert but will have a go at simple repairs .The main problem on this amp is that the reverb send signal is none existant ,i have swapped valves and also fitted a new driver transformer but still nothing ,I can not make any sense out of the schematic and cannot find a layout diagram for it,could anyone suggest if it maybe a resistor or cap at fault ,any advice would be greatly appreciated, cheers .
fender ,93 the twin ,red knob
What test equipment have you got?
Are you aware of safe working practice, eg Safety Tips For Working On Tube Amplifiers
Is R56 the V8 reverb driver cathode resistor ok?My band:- http://www.youtube.com/user/RedwingBand
Also, you mentioned you have no "reverb send signal", but we should begin from scratch.
How did you determine the send signal is non-existant?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by sid View PostHi i am new to this forum,i am wondering if there is anyone out there who is familiar with the "fender twin red knob amp " ,I have recently got it to restore ,i am not an electronics expert but will have a go at simple repairs .The main problem on this amp is that the reverb send signal is none existant ,i have swapped valves and also fitted a new driver transformer but still nothing ,I can not make any sense out of the schematic and cannot find a layout diagram for it,could anyone suggest if it maybe a resistor or cap at fault ,any advice would be greatly appreciated, cheers .
red knob
Originally posted by sid View Post...someone has taken the tank out and just instaled in out jack plugs on the back of the cab ,why i dont know ,so i want it put back to original spec .
If you have a camera, post a photograph of the reverb area of the pc board and perhaps we can see something that has been altered.
How about that switch Pedro asked about in post #5?
That is what routes the signal to the driver tube.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
ok i will get a photo tomorow ,there are two wires that have been cut and cannot see where they went ,one goes from reverb 3 on the pcb (the centre one )the other comes from the mains transformer tag BR its a thin black wire,looking at photos on the web these two wires disapear under the front pcb where the knobs etc are ,but theres no photos of the underside .
Attached is a gut shot of a stock 1990 "The Twin" which will be useful for you to see how they were originally wired. The resolution is good enough that you can zoom in to trace some of the wiring.
My tip is that you be VERY careful if you ever try to get to the far side of any of the PC boards. This is because the flying lead wires are not properly strain relieved and Fender used brittle 7 strand wire. The strands break easily (Birdcaging) when flexed to flip the board over and it doesn't take long before the wires break completely free.
Very strange that someone would have moved the reverb send & recover connectors to the rear panel of the chassis.
Cheers,
Tom
Originally posted by Tom Phillips View PostAttached is a gut shot of a stock 1990 "The Twin" which will be useful for you to see how they were originally wired. The resolution is good enough that you can zoom in to trace some of the wiring.
[ATTACH=CONFIG]33184[/ATTACH]
Cheers,
Tom
Fly lead strain relief
Regarding the crappy fly leads in "The Twin." It is interesting to note that the earlier versions of the amp had strain relief holes in both the front panel and the main PCBs which the flying leads could be looped through to provide strain relief. However, in the examples I have seen, Fender did not loop the wire through those holes and the earlier amps had the same birdcaging wire issue. The assembly procedure fix should have been to route the wires through the strain relief holes but Fender revised the PCBs and the holes were eliminated on the new rev.
I haven't seen one of these evil twins in a while. Do the have an fx loop? If not, it may have been half ass modded for an fx loop. Try taking that send on the back as it exists and running it into another amp. If there is a signal there to amplify, then stick a pedal or rack effect between the existing in and out as is. If it works, you might be better of just putting a cheap stomp box reverb (or multiple effects whatever) there and be done with it.
