Results 1 to 25 of 25
Thread: Heyco Strain Relief Tool
    Senior Member patlaw's Avatar
    Jun 2012
    126
    My Leslie amp and other pieces of equipment use Heyco strain relief bushings to secure the power cord. These suckers are hard to get out and back in without the right tool. Heyco sells several sizes of pliers for the task, but it looks like I'd have to have two models (22 and 30) to cover most bushings. That's about $200 worth of tools to use ten times.
    What do you use to remove and reinstall these parts? I usually end up with a small pair of Channel Locks or a large pair of needle nose pliers. Both tend to booger up the strain relief.
    Jun 2006
    California, USA
    3,473
    Received: 23/0
    Given: 16/0
    I know what you mean about the price per use and I really agonized (a long time ago) about spending the money for the specialty tool. However, my price per use & the part and finger damage avoided over the years has been worth it. I use the model 22 which is advertized to fit "all strain relief bushings for chassis ports up to 7/8". I have never needed a different size tool. It is "adjustable" in the sense that you can remove the pivot screw and move the jaw position on the gear. I have done that when I used it for very large or very small strain relief bushings. Hardly ever need to do that though. I wouldn't want to be without the tool now.
    As I understand it the model 30 is a heavy duty version of the model 22 but it fits the same range of parts. The 22 has been adequate for my use. One supplier's info with photo is at the link below .
    Heyco - 0022 - Strain Relief Bushing Pliers
    Old Timer tedmich's Avatar
    Apr 2008
    Sonoma CA
    3,160
    Received: 24/0
    Given: 37/2
    these work great ! A little slow from HK but only $5
    Electrical Strain Relief Bushing Assembly Pliers Tool | eBay
    decent needle nose pliers and heating units in boiled water also work good
    Jun 2012
    126
    Quote Originally Posted by Tom Phillips View Post
    That's what I was really curious about. The strain relief on the Leslie reverb amp is quite large - probably 9/16" or more. If the 22 will work for the large one as well, I may pull the trigger and get one. Mouser has them for $55. I should have bought them 30 years ago like I did my Keystone 1707 staking kit and my Roper Whitney No. 5 Junior punch set. Both tools have been indispensable over the years.
    Feb 2010
    9,936
    Received: 133/0
    Given: 299/0
    I use the cheapie like Ted posted and have never had any issues.
    That being said, when someone else was footing the tool bill, it was very nice to use the "official" tool , very high quality that you can feel.
    Old Timer km6xz's Avatar
    Dec 2010
    St Petersburg Russia
    1,840
    Received: 2/0
    I have had many specialized crimping tools that were really expensive but never felt the need for a strain relief tool when the long nose vise grip tool was right in the tool cabinet. It does not have the rough corrugated surfaces that the normal vise grip pliers do. I had one of the simple ones that Xilite used to have, like the one Ted showed but lost it 10-15 years ago. They work fine on smaller strain relief but need more gripping power leverage for the large ones.
    Jun 2006
    California, USA
    3,473
    Received: 23/0
    Given: 16/0
    That HK tool for $5 looks like a real bargain.
    On thing I like about the purpose built tools like the 22 is that it doesn't just squeeze. It holds that strain relief so you can pull and push to remove and install.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,226
    Received: 186/0
    Given: 262/0
    I'm with Stan. I don't do repairs often and I've only had to crimp maybe half a dozen of those bushings in my life. So take this with all the salt you like, but I don't, and probably won't have any unitaskers in my tool box. I have misc. special nosed pliers and I've managed. FWIW those Heyco bushing pliers look TOO burly. If you need a cam levered pinch on the bushing you're probably squeezing it too damn hard to be safe for the wire jackets! JM2C on that.
    OTOH if I crimped a bushing every day (or maybe once a week) I might buy the Heyco tool.
    "I'm just going to perform a bit more scientific investigation, turn it up to 11 and rip of the knob." überfuzz
    "If you build it, it will hum..." Justin Thomas
    Feb 2010
    9,936
    Received: 133/0
    Given: 299/0
    Stiffer cords that are a snug fit in the bushing take a lot to kink the whole cord. The cam leveraged tool is probably the only one that works well in that case. But as you say, unless you are doing a lot of cord replacements, it may be overkill. On an assembly line it would be essential (unless that job is now robotic).
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,173
    Received: 268/1
    When I have to squeeze a stiff jacketed wire into one of these, instead of fighting it, I get out the heat gun and warm the area to soften it.
    1 Not allowed! Not allowed!
    May 2007
    pacific north west
    13,226
    Received: 186/0
    Given: 262/0
    Well then... Look at you! With all yer fancy "thinkin" n stuff.
  12. #12
    30,173
    Received: 268/1
    A lot of things are better if you warm them up first.
  13. #13
    May 2007
    pacific north west
    13,226
    Received: 186/0
    Given: 262/0
    Your slipping Enzo! Juan would have made that statement and followed with this image:
  14. #14
    Feb 2010
    9,936
    Received: 133/0
    Given: 299/0
    Or a pic of one of his "blue" steaks, you know, the kind you pick up with a fork and shake it at the sun for a few minutes to "cook" it.
  15. #15
    30,173
    Received: 268/1
    Well, I tried to be subtle...
    Cherry scented, my ass.
  16. #16
    Old Timer
    Chill-Ville, VA
    2,514
    Received: 53/1
    Given: 132/3
    So, who wants to go first and rate this thread "5 Stars?"
    I <guess> it's related to "strain relief" in a way...
    Justin
  17. #17
    30,173
    Received: 268/1
    We all relieve strain however we can.
  18. #18
    May 2007
    pacific north west
    13,226
    Received: 186/0
    Given: 262/0
    My wife is wondering why I'm laughing like a loon with the TV off and no one else in the room!
    Enzo put it out there, I shoved it to the edge and he steps back in and just kicks it right the F off. Five stars!.. Strain relief... Pfft... Love it.
  19. #19
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    4,942
    Received: 101/0
    Given: 61/0
    I was going to put up a photo of a can of mushroom soup. You guys are wacky!
  20. #20
    Apr 2008
    Sonoma CA
    3,160
    Received: 24/0
    Given: 37/2
  21. #21
    Sep 2012
    Dogpatch-on-Hudson
    4,942
    Received: 101/0
    Given: 61/0
    tedmich, if the brand name was the next island over, Assateague, you'd have a real knee-slapper!
    FWIW I happen to know both Chinc- and Ass- ateague are in Maryland, some distance from New England, they got a lot of nerve claiming New England clam chowder. (I know, it's the creamy type not the minestrone + clams type Manhattan c.c.)
    And it does work better warmed up, who wants cold chowda. Hell I even boil up my vichysoisse, don't need a free botox fix.
    "While I'm workin' my ass off, you guys are clammin' it up! You're all fired!" (Buddy Rich famous tour bus rant, for a real laugh look it up & have a listen.)
    If you see food eat it.
    If I see a Heyco strain relief, I break out the ol' water pump pliers AKA channellocks. One more tool and my rack will 'splode.
  22. #22
    30,173
    Received: 268/1
    Not to mention the famous bearded clams...
    And now I am off to the things don't smell like they used to thread...
  23. #23
    May 2010
    Sioux Falls, SD
    5,159
    Received: 126/0
    Given: 103/0
    I'm bummed. I missed the entire downslide. I'm always up for a distasteful diversion.
  24. #24
    Apr 2008
    Sonoma CA
    3,160
    Received: 24/0
    Given: 37/2
    he was NOT a nice guy...
    I find frozen peas funnier:
    https://www.youtube.com/watch?v=Ol5RpDEzLzY
  25. #25
    4,449
    Received: 69/0
    Given: 57/0
    I have a lower wattage hobbyist heat gun perfect for heat shrink tubing and the like as well as the industrial strength one from Harbor Freight. I just now ordered the next to the last one in the eBay link above, now up to $6.xx...
    Steve A.
  1. New Winder building tool? (a bit OT, but it is a tool!)
    By kayakerca in forum Tools and Coil Winding Gear
    Last Post: 03-05-2013, 12:41 AM
  2. DIY Solder Fume Extractor (Comic Relief)
    By rjb in forum Music Electronics
    Last Post: 05-07-2012, 08:39 PM
  3. replacing power cord strain relief
    By EETStudent in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-03-2012, 05:53 PM
  4. Hand winders... do you get eye strain?
    By FunkyKikuchiyo in forum Pickup Makers
    Last Post: 02-13-2010, 12:40 AM
  5. Strain relief when replacing 2-prong power cords
    By Ptron in forum Repair and Restoration
    Last Post: 04-04-2009, 02:31 AM
