Guitar troubles - volume knob
  • Guitar troubles - volume knob
    Can anybody help me out? The volume knob on my guitar has come off and it won't fit back on. I play an ESP MH250 model (see the photo).
    Basically, the volume on the guitar still works but it's just a hassle to use now. I'm not sure if I'll have to replace the volume control completely. If so, could someone tell me a good place to order parts from and exactly what I'll need?
    I want to avoid going to a guitar shop if necessary because they're so expensive.
    Youll need to get an allen wrench to run the set screw out. Then set it back on the pot and tighten it down. Its probably a 2mm I think.
      if you are tightening the screw on the knob but it still wont stay, the split top of the potentiometer may be pushed together, where they should have a little space in between them. its hard to tell from the photo, though. good luck.
