Marshall JCM2000 TSL100 Footswitch problems
  • Marshall JCM2000 TSL100 Footswitch problems
    Anyone have experience troubleshooting a non working 5 switch footswitch for the TSL100? I haven't been able to find a schematic for the footswitch so I'm having trouble tracing the problem. The led for the clean channel works when that is pressed but when I press the lead or crunch switches the clean led goes out but the others don't light. The footswitch uses a Nand Gate which seems to be working then the output for all three preamp functions appears to go through a white wire to the din plug on the amp. From there I can't follow the schematic because they seem to be changing the connector #'s with no reference. I'm quite familiar with american brand schematics but I haven't figured out the Brit ones yet. Anyway any advice on how to troubleshoot this would be helpful
    Paul
    All that I have is:
    If you are a member: MarshallForum.com
    All the footswitch does is ground out each function.
    Can you point out where the Nand gate is ? (page#/ coordinates)
      The nand gate is actually on the footswitch circuit board along with 3 transistors, a darlington pair and some caps and resistors. The 3 preamp control switches are momentary contact switches feeding into the Nand gate. The reverb and FX switches are 2P2T.
      So far I can't find anything about the footswitch online. I just became a member of the Marshall forum so thanks for that info. I'll dig in deeper tonight when I get back home.
        See if these are any good: MarshallForum.com - View Single Post - TSL100 Footswitch schematics (new member)
          That's great, They had the schematic for the footswitch. That should help me trace the problem. Thanks
            Uhmmm...
            Can you post it?
            Edit: Joined and have it.
              Well I discovered that 2 buttons on the amp head have to be pushed in for the footswitch to work. One of the original problems was I had a bad LED as well as not having the buttons pushed in. I'm not sure if I inadvertently fixed the switching problem or the owner of the amp didn't know to push the 2 switches. I should have downloaded and read the owners manual before I started. Lesson learned. Thanks for everyone's help
                Who reads the manuals????
                  Actually I got caught like this a few times in the past....Now I download the user manual and take a quick look...I had a Marshall mini stack that had a footswitch problem.....the foot switch was supposed to be programmed from the factory to a set of defaults....this one was not and I never knew until I read the manual....I thought there was a problem with the switch assy....so now, whenever I get something that I am not totally familiar with I search for the owners manual first before I even open it up....
