Multi-Scale Guitars
I've been moving along with this in my spare time. I glued up a poplar body for it this week. This one's an experiment, so I don't want to use expensive material. The next one will be a little fancier. The scale lengths on this are 25.5/24.6... The layout is achieved by marking the fret positions of the two different scales, and connecting the marks. The biggest obstacle in building one of these is finding a bridge system that costs less than a Lamborghini. Inexpensive single string bridges for basses are easy to find, but I haven't been able to locate any for guitars. I'll be using a modified 6 saddle telecaster bridge on this one. I'm awaiting it's arrival from the other side of the earth, but I'll carry on. Stay tuned.
Rondo sells their Agile Pendulum bridges pretty cheap
Agile Pendulum Bridge / Saddle - RondoMusic.com
sadly they look it
this price is easier to understand than Allparts of $36...each!
People also like using Wlkison/Graphtech saddles on custom flat base plates, hope the Tele bridge form the far east works out!
Thanks Ted, I hadn't seen those. They do look pretty cheap, but it's nice to see an alternative to the expensive systems. I've been looking at different types of bridges trying to come up with something I could do by cutting, and modifying one. I still may make my own segments, and use fender style string through saddles.
I've been designing this thing on the fly, and I'm not really sure what I'll do for electronics yet.
I'm on the fence on whether to do a six on one side, or a 3x3 snakehead.
I'm thinking a metallic blue with white plastics would look good with the maple neck.
That's not quite as fanned, and as discrepant a scale length from bottom to top, as some I've seen. So it may well be possible to accommodate the different scale lengths with a Telecaster-type assembly, or hard-tail Strat setup, and some longer adjustment screws and springs. Naturally, it would have to be strung-through type, rather than a through-body type.
Or am I sorely misjudging something about the stability of such an approach? For instance, what happens when the saddles are nut snuggled up in close proximity to each other.
Originally posted by Mark Hammer View PostThat's not quite as fanned, and as discrepant a scale length from bottom to top, as some I've seen. So it may well be possible to accommodate the different scale lengths with a Telecaster-type assembly, or hard-tail Strat setup, and some longer adjustment screws and springs. Naturally, it would have to be strung-through type, rather than a through-body type.
Right on, another multi-scale convert! This is all I build, and I think a lot of players are coming around to seeing this as an appropriate and functional evolution of the guitar, especially where extended ranges are concerned.
So, it looks like you put the perpendicular fret at the 9th? In the future, if you're only splaying your scales by an inch, putting the perpendicular at the 12th won't be much different in feel, and you'll have to deal with less of a difference at the bridge.
I'm one of those people who uses the Graph Tech Wilkinson saddles on a flat bridge plate. I get mine on amazon. This is a really easy DIY solution, and even if you don't get your post screw holes exactly equidistant, you can still pivot the saddles for correct string spacing. Making a bridge plate out of 3/16" aluminum sheet stock would be my suggestion.
As for pickups, don't worry about tilting them to match the bridge. You can do that, of course, but it requires custom base plates and covers. With the design you have, some of those dog-eared P-90s you thermoformed would look cool.
Oh, and a 3+3 headstock would look best, in my opinion.
Keep us updated!Last edited by Jason Rodgers; 08-09-2015, 04:35 AM.
Originally posted by Jason Rodgers View PostRight on, another multi-scale convert! This is all I build, and I think a lot of players are coming around to seeing this as an appropriate and functional evolution of the guitar, especially where extended ranges are concerned.
So, it looks like you put the perpendicular fret at the 9th? In the future, if you're only splaying your scales by an inch, putting the perpendicular at the 12th won't be much different in feel, and you'll have to deal with less of a difference at the bridge.I'm one of those people who uses the Graph Tech Wilkinson saddles on a flat bridge plate. I get mine on amazon. This is a really easy DIY solution, and even if you don't get your post screw holes exactly equidistant, you can still pivot the saddles for correct string spacing. Making a bridge plate out of 3/16" aluminum sheet stock would be my suggestion.As for pickups, don't worry about tilting them to match the bridge. You can do that, of course, but it requires custom base plates and covers.With the design you have, some of those dog-eared P-90s you thermoformed would look cool. Oh, and a 3+3 headstock would look best, in my opinion.
Keep us updated!
Originally posted by John_H View PostI thought about squaring it further up, but it seemed to me that it might be difficult to play chords in the first couple of positions that way.
If you're thinking about making more than one of these beasts, I suggest building this adjustable fret saw jig. I got the idea here Multiscale Fret Slot Jig - Australian/New Zealand Luthiers Forum
I had a few things to consider when I did the layout for this, but the foremost was how much compensation I could get from a modified tele bridge. Secondly was to keep it close to perpendicular in the middle of the neck. There's no book on these. I'm sure that most who endeavor to make one either step up with their own design, or reverse engineer what others have done. There isn't that much to go on. It's a newer frontier in a craft where almost everything has already been done. The fact that no major makers are building these adds to the mystery. I believe that will change soon because the popularity of this is surely on the rise.
The fret slot jig looks like it would be helpful cutting fingerboards. I like the neo magnets holding the blade to the guide. That's clever. I build a lot of one piece necks though, and it wouldn't be applicable. I do have a couple of new ideas after looking at it though. Thanks!
Originally posted by John_H View PostThe fact that no major makers are building these adds to the mystery. I believe that will change soon because the popularity of this is surely on the rise.
Originally posted by tedmich...If however you want near perfect intonation all over your >6 string guitar you need tru temper frets....
I agree Ted. The benefits of different scale lengths would certainly be more apparent on an extended range guitar or bass. I decided to make my first effort a little less complicated, and more like a regular guitar.
Originally posted by JasonWell, at NAMM this year, Ibanez introduced a Fanned Fret (yes, licensed through Novax) bass guitar.
I laid a three saddle tele bridge that I've cut down for another one that I'm building up on the guitar to illustrate how it will work. There's plenty of room for compensation. I don't like the angled pickup.
Originally posted by John_H View PostI laid a three saddle tele bridge that I've cut down for another one that I'm building up on the guitar to illustrate how it will work. There's plenty of room for compensation. I don't like the angled pickup.
