Hi All,
I'm currently restoring an Echoplex EP3. It sounded pretty rough when I got it. High noise floor, some general reliability issues. So far I've replaced all the electrolytics which cleared up the noise, put in a fresh tape cartridge, demagnatized the heads, cleaned and lubed all pots, replaced the pinch roller, put on a fresh belt, cleaned the motor, leveled the motor, cleaned all surfaces, and straightened the rails the moving head travels on.
It's running almost perfectly...
Right now, even with no input, it runs away when the Sustain knob hits about 7. Just goes from dead silent to runaway with nasty static noise. With a guitar signal it's got the same problem, and it seems to run away with this static sound earlier than it should, it's hard to get lengthy decay on the guitar. Just goes from medium decay of guitar sound to runaway with static.
Sounds fine with the knob below 6, which is where I use it most.
Any thoughts on what to troubleshoot next to combat this? Or is this normal, and I'm simply just not remembering how these normally behave....
Thanks!
Thanks!
