Here are 2 graphs showing the difference in resonant peak frequencies on a 7k un-potted humbucker. One graph represents the difference between single conductor and 4-conductor. The other graph represents single conductor vs 2-conductor. Same exact pickup and lead wire lengths were used, just swapped lead wires only. I get asked from time to time how different lead wires affect the tone of a pickup. Hope you enjoy.
Single vs 4-conductor resonant peak
Originally posted by Mike Sulzer View PostAnd how does the way the conductors are connected affect the response at about 1 KHz by about 20 DB?
I did a thread on this a couple of years back. It was sparked by my QC observation of a performance shift when I switched 4-conductor cable vendors.
Frequency response data, not to mention AC parameters, are pretty sensitive to cable capacitance.
Unfortunately, the links in that old thread were broken when we updated our website. Here's the gist of it:
I recommend that my customers don't ground the cable shield unless they have buzz issues. From a fidelity standpoint, twisted pairs and cavity shielding are much better than shielded cable.
Originally posted by ScottA View PostThat looks like an artifact, but the response at higher frequencies is consistent with what I've seen.
Originally posted by Mike Sulzer View PostBut does it make any audible difference, or significant measurable difference when the effect of the capacitance of the guitar cable is included? Remember 5KHZ is a pretty solid per limit for electric guitars.
I study pickups unloaded because that's where you can see the detail. That detail is important installed in a guitar even if it is hard to measure at the end of a guitar cable.
There are limits of course, but that's part of the trick, too. Minimize the loss due to controls by carefully designing your control scheme, low cap cable, well placed buffers, etc.
Originally posted by ScottA View PostThe idea of things not being important because they get buried in the noise of the control and wiring loading is a red herring.
Originally posted by Mike Sulzer View PostOriginally posted by ScottA View PostThe idea of things not being important because they get buried in the noise of the control and wiring loading is a red herring.
In the data I show above, there are easily discernible differences in the 1-5 kHz range. In practice, these kinds of changes are what you hear in the "high end air" for lack of a more scientific term.
I can tell you that the difference between the red and orange series (i.e. the two 4-C cable vendors) looked like a different pickup in my final QC metrics. Definitely outside the control limits. That's what sparked me to do this analysis in the first place, response to an out of control event.
(In Capt Kirk voice) Must...have...assignable...cause...Last edited by David Schwab; 08-13-2015, 11:32 PM.
Originally posted by Mike Sulzer View PostOriginally posted by ScottA View PostThe idea of things not being important because they get buried in the noise of the control and wiring loading is a red herring.Last edited by David Schwab; 08-13-2015, 11:32 PM.
Originally posted by zparts View Post
I test pickups unloaded just to keep things consistent with how I test everything else. The reason I don't bother with adding variables is because I can't control them once the pickup is in someone else's hands. This graph simply demonstrates how connecting the coils together in series through the length of a cable can change the resonant frequency. Now connect the coils at the pickup in series and just use 2 of the 4 wires of the 4-conductor wire for a hot and ground, and the frequency won't shift much or any at all compared to any other lead wire of similar length and gauge.
A. unloaded
B. loaded with guitar cable
Suppose the loaded capacitance is 5 times that of the unloaded. (With a humbucker the capacitance from the series combination (two caps in series have half the capacitance) might be 80 pfs. 400 pfs with the cable cap added is not that unusual.) Suppose we add a small capacitance in parallel in both cases. Suppose that in case A the resonance shifts by x Hz. Then in case B the resonance shifts by about x/10 Hz.
You can see this from these calculations assuming a 3 H inductance.
In [37]: 1/(2*pi*sqrt(3.*80e-12))
Out[37]: 10273.407401024997
In [38]: 1/(2*pi*sqrt(3.*81e-12))
Out[38]: 10209.794359662816
In [39]: 1/(2*pi*sqrt(3.*400e-12))
Out[39]: 4594.4074618482673
In [40]: 1/(2*pi*sqrt(3.*401e-12))
Out[40]: 4588.6751982787782
Or you can find the derivative with frequency and see that it varies as C**(-3/2).Last edited by David Schwab; 08-13-2015, 11:34 PM.
[QUOTE=Mike Sulzer;392067]Originally posted by zparts View Post
Great way to test for consistency because it shows up small differences. But that sensitivity cannot be used as an indication of how much things change with a guitar cable in place. Suppose we have two situations:
A. unloaded
I look at it as loss of fidelity.
Any capacitive loading like that leads to a loss of fidelity in some sense. If I can see it in the measurements, then at the very least there is the potential of an effect on the tonal quality.
You can't control what people do, but you can give them guidance on how to get the least affect on, or coloration of, signal quality, or at least to have that option on tap.
The unloaded measurement gives what the pickup is capable of. Of course some amount of loading is usually desirable as "everything the pickup is capable of delivering" is, many times, harsher than what most people want to hear. It's also kind of "built in" to the designs anyway. I target voicings and analyze data based on the unloaded measurements, but when I'm evaluating performance I'm playing through a realistic, representative rig, albeit designed with loss minimization in mind. I use low cap cables and buffers in the right places, but I'm usually running through at least the equivalent of 10-15 feet of low cap cable as well as an optimized set of controls. That filter is built in to the design loop.
Look at it this way: The measurements tell you when you should be looking for a tonal difference, then you can let your ears tell you if you care about it or not.
My general philosophy though, is to make the sensor as good as I can, and part of that is minimizing losses due to coupling. If people want to muck it up downstream that's their business.Last edited by ScottA; 07-30-2015, 02:31 AM.
Originally posted by ScottA View PostI look at it as loss of fidelity.
If you are trying to reproduce a guitar sound from the past, then just do things the way they were done in the past, or find a new way to get the same sound. But a few pfs of C in lead cables has nothing to do with it.
Originally posted by Mike Sulzer View PostFidelity is faithfulness to an original. If you are trying to create the tone you want, then fidelity is an irrelevant concept. Fidelity to what?
Sound quality, whatever you want to call it. Excuse me for using "fidelity" in the sense of the audiophile marketing voodoo, but I think in the context of the vernacular, we all know what it means.
The data show this clearly. Add capacitance, and the frequency response is shifted from what the pickup is capable of producing. "Degraded" I think is not an incorrect way to look at it. So in that sense, I would say yes, it is "unfaithful to the original".
Mike, you seem to be a very intelligent guy, but your condescending tone becomes tiresome.
