1965 Supro Amp
Here is the 6420T.
3 12AX7, 5U4 & 2 6L6.
Supro_6420TR.zip
And the infamous Jimmy Page amp, the 1690T.
Supro 1690T.pdfAttached Files
http://www.dirtygirlamps.com/Amp_sit...iles/1690T.pdf
Should be close. Has two 6l6's. One site cross referenced the amp as a 1697t, Thunderbolt combo tremolo.
(Or you could send me the amp and I'll draw up a schematic for you. )
[ATTACH]35164[/ATTACH]
[ATTACH]35163[/ATTACH]
Are we saying there is no schematic for the 6497T ?
Maybe I won't need one but it would be nice to have.
Doc
I drew one out the last time I had one here but it's just hand sketched, I haven't converted it over to a 'nice' schematic like the others. If I can find it and it's readable I'll scan it and post it. These are not my favorite amps, in fact the first one I had a few years back had all kinds of weird problems and I finally just gutted it and built something else into it. I've worked on a few more since; assuming you know for certain that your tubes are good and you're getting juice to the preamp and the output, the first thing I would check is the output cable to the speaker. Make sure the cable is functional, make sure the speaker is not blown and then - REALLY IMPORTANT - make sure the socket for the output cable has not corroded or cracked and subsequently is grounding the positive to the chassis. The 'socket' is just two square pieces of garolite or whatever with two tabs for the cable pins and the whole contraption is riveted to the chassis. They went from real 4 pin sockets to these around 1962-ish or so, and I've had a couple that were cracked and grounding out the speaker output.
Originally posted by Doc Stitches View PostEFK
Thanks for the pointers. I will follow them in order.
First thing I need to get today is a 5U4 ............. I thought the socket stamp was 5Y3 ( light rust made it impossible to be certain )
The chassis design does look a little on the "cheesey" side.
Hey EFK ... you were right ... speaker cable was grounding positive to chassis. Still checking other stuff......
at least it looks like no one has been in the amp.
The 15 in. speaker is only reading 7.6 ohms ... is that an issue ?
