Yamaha EMX512sc main out LEDs not working
  • Yamaha EMX512sc main out LEDs not working
    Hello everyone. I purchased a used Yamaha EMX512 and everything works fine, except the main LEDs do not light up at all. The monitor Leds work fine. There are LED drivers for Left and Right main outputs. Any ideas? Thanks!
    Schematic Link:
    YAMAHA EMX512SC-EMX312SC Service Manual free download, schematics, eeprom, repair info for electronics
      Thanks for the link!
        Here's a simplified section of the schematic and the board.
        I guess I'd start by checking for the supply there at pin 9 , 12 volts
        and then check for some audio signal at pin 8 of the LED driver IC the LB1423N.
        Careful of the switchmode supply it's live and dangerous ... you may have to connect the
        front foil to the one in the case .. I recall some discussion about the supply.
        It wouldn't start up unless the foils are connected.
        You could also compare readings with the "good one" the monitor led VU. as that may give some clues.
Name:	Yam LED VU EMX512sc page38.jpg
ID:	840563Click image for larger version
Name:	Yam LED VU EMX512sc page137.jpg
        Here's a link to the grounding info JP Bass made from a post by 1984ARC should you require it.
        http://music-electronics-forum.com/a...o-emx512sc.pdf
          Thank you very much! Very helpful!
          [ATTACH=CONFIG]37172[/ATTACH][ATTACH=CONFIG]37173[/ATTACH]
