JBL eon 510 broken OUTPUT (mix/loop) and EQ
  • JBL eon 510 broken OUTPUT (mix/loop) and EQ
    Hi everybody.
    I got two problems with my box.
    1. changing the EQ in position makes a VERY loud crack when the box is turned on.
    2. the OUTPUT is broken. The box itself works fine, but when try to use the LOOP/MIX function via OUTPUT the box is shut down some how (not out JBL speakers and not out on external devices i loop to).
    I used the LOOP function for a long time to send it to mixer/PA.
    but once it stopped working with a little crack when pluging in the XLR into OUTPUT.
    does any one has hint what on the PCB went broken?
    thankful for any idea.
    cheers
    dot
    Manual:
    http://www.jblpro.com/ProductAttachm...Eng.072610.pdf
