Singlecoil vs humbucker # of rounds
  • Singlecoil vs humbucker # of rounds
    Hello all,
    I'm planning to make a split coil jazz bass pickup. When singlecoil jazz bass pickup has around 9500 rounds of 42AWG what amount of rounds should I aim for in split coil version? I'm looking for something to start with, not your secret recipe for the Gral of Sound.
    Marko
    Originally posted by Marko Ursin View Post
    Hello all,
    Marko
    A good starting point is the recipe for the Precision Bass' split-coil design of 10,000 turns-per-bobbin.
    HTH,
    Pepe aka Lt. Kojak
    Milano, Italy
      Can you give us your bobbin dimensions?
      That will determine how many turns you can put on the coils.
      When you split the coil into two pieces?
      You are limited to the amount of turns you can put onto the adjoining ends, in the center of the pickup.
      T
      **If you look at this drawing, you can see how short the ends will be, when you cut the bobbin in half in the middle of the pickup.
      http://www.seymourduncan.com/wp-cont...06/SJB-12b.pdf
        I know it gets tight in the middle. I may just wind the coils as full as possible and take a listen to the pickup. I plan on winding with 43 wire to get more rounds. Tomorrow I'll know more as I'm planning to wind two coils in the morning.
          You may want to try the large single magnet split coils.
          I did a project on that last year.
          I did 10,000 turns of 43.
          All the specs are there, and it worked great!
          http://music-electronics-forum.com/t39825/#post390633
            The 43awg should definitely get you past the 10k mark. Tradition rear pickup mag spacing was .78" with .275" pair spacing. If your mags are .78" tall (20mm) and .1875 dia you can get 10k of 42SPN on if you use the 1/16" thick flatwork instead of 3/32".
            Where you really run into trouble is with .750" tall x 5mm magnets with 3/32" flatwork and .550" tall coils that have .725" spacing for the bridge position. If you like to wind with HPN it gets even worse. I use .850 x .187" mags and I have the pairs almost touching. That way I can easily get all the wire i could ever want on there and have some magnet sticking up flush with the top of the cover.
              10000 rounds of 43 AWG fitted just fine. I have the poles slanted like on Nordstrand pickups. I have a small cnc router at work so making bobbins is a lot easier now. I have to know how CAD and CAM work before teaching that to kids, right
              I'm mounting these coils to Bartolini BC covers, next I have to drill or route the holes for the polepieces on the covers, then I'm ready for assembling the pickups and testing them.
              And covers drilled. I really love the accuracy cnc gives. I drilled the covers by usin base plates as templates on a pin guided drill jig. I used one magnet rod as pin. Everything just snaps together.
              As for sound I taped the pickup on my bass using legos as shims and I have to say that I like the sound so far. I have to rout my testbed bass for these pickups for further testing.
                See? Told ya!
                Pepe aka Lt. Kojak
                Milano, Italy
                  Hi Marco, can you be SO nice to tell us where you buy those so "sought after" covers?
                  I've done some of those kind of pickups already, (I've also a cnc as well )...Click image for larger version
ID:	840880Click image for larger version
                  but the bart like covers are actually difficoult to find in small quantity...
                  Thanks.
                    Christoph at Bassculture.de has these covers. I've bought mine from him.
                      Thanks a lot, i'll try with him.
                      Actually i'm building an 8 coils on a MM cover, I'll post the pictures soon.
                      M.
