Just checking if anyone has come across any amp using a push-pull driver stage, where the drivers appear to include substantial grid-leak biasing with signal operation. The schematic from a clone that is just being fired up shows 2M2 grid leak, although the original circuit used 22M. The clone idles with about 77V on screens, and 200V on plates and 1.7V on cathodes, for a 335V supply and using 6SJ7's (instead of 6SK7's).
Will try and check what the V6/7 anode voltages shift to when signal provides some additional negative biasing.
Ciao, Tim
Ciao, Tim
