Friends....
I thought it would be a good idea to open a new thread and focus on just one thing- the speaker in the Peavey Ecoustic 112. The info in this thread could apply to other Peavey Speakers, but let me stick to this particular speaker.
This speaker is a 4 ohm, coax. The tweeter has it's own terminals and uses fuses and a single cap for the crossover. I found a 6.8uf cap solders to the terminals. So I am guessing that a single order crossover means this falls in the neighborhood of a 6Khz crossover. I could be wrong.
The cap is open and the diaphragm melted. Its mostly also a 4 ohm diaphragm.
I have contacted Peavey to see if they have a replacement part and specs for this speaker and the tweeter. Perhaps we'll get a reply.
In the meantime, here are some photos.
While waiting for Peavey to respond, I am going to search and see if I can find a 3rd party replacement.
And then... the crossover. I don't know if a simple cap will suffice. Perhaps I will look for a high pass filter or 2 way. And the cut over will depend on the diaphragm specs. The woofer will go full range.
