Subwoofer problem Mackie swa 1801
  • #31
    Do you know the voltage of the amplifier? The old owner has changed transformer and I do not know if that is the right one. The mounted transformer is 800VA with +- 90V DC and +- 18V DC. The +-18 V DCs are right because the schematic is written so, but other tensions do not know them.
    • #32
      The power supply high tension filter capacitors are rated for 100 Vdc.
      So 90Vdc will work.
      It may be a bit high.
      • #33
        Ok thanks, but what is the original voltage of the amplifier?
        • #34
          I do not know.
