DC resistance of a two string pickup
  • DC resistance of a two string pickup
    Hello,
    I'm windind pickups for a homemade 4 string bass and I'm planning to separate the strings in 2.
    I want to wind two pickups of two strings who will go separately (two outputs) in two different amps.
    The pickups will be single coils with single A5 rods.
    Since I saw that the fender jazzbass pickup have around 10000 turns, I was planning to go for that and to have an approximate fiberboard spacing of 17/32 of inch.
    But that is not why I'm posting.
    Now if I think in terms of DC resistance, I should (almost) double the number of turns to get the same DC resistance (compared to a 4 string pickup).
    First question : Is it correct to think this way ?
    Then second question
    If I think in terms of sound, will I get approximately the same sound with :
    - a 2 string pickup that has 20000 turns (a little less because the length is not strictly divided by two)
    and
    - a 4 string pickup of the same characteristics but with 10000 turns ?
    I hope I'm making myself clear...
    Thank you,
    Julien
    Hi Julien:
    On the turns, a turn is a turn.
    So if you have a 1,2, or 4 sting coil.
    One turn is a turn for each and all of them.
    So one coil for all 4 strings 10,000 turns.
    2 coils per string, still 10,000 turns.
    Explain how you are building the 2 coil pickup.
    Sounds like a P-bass pickup?
    T
      T
      Thank you big tee.
      It makes sense, and this is one more reason to see that DC resistance does not say much about a pickup.
      My pickups will be very simple. It will be strat pickups but with higher rods and a higher bobbin.
      Each two string pickup will go to a volume, then to an output.
      I hope to get more clarity for some chord playing... and I want to get spatialization effects...
