Looking for stacked pot
Fender uses one in some of their Deluxe basses. Detent in both sections. Not sure if it is linear or not.
Fender part # is 005-3736-000
Looks like this:
Fender 100K Conentric Stacked PotentiometerOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by MarkusBass View PostThank you. I found out that both EMG and NOBLE manufacture very similar pot. I'll try contacting bestbassgear to find out who the real manufacturer is.
Mark--Charlie Escher
Markus.
This pot looks like it came from a Fodera/Mike Pope preamp. Most preamps use a linear pots i.e. "B" taper. Very hard to find item if you don't have the bass serial number in hand. Try Fodera directly but expect to pay 10X what the part should cost. You can probably get a similar pot from MEC in Germany for a lot less. Try through <hansal at MEC-pickups dot de>
Otherwise you'll have to use the b50kdc post from Best bass gear as was suggested. It will work fine but with a slightly reduced range of effect. Noble - EQ Pot - 50K Stacked - Best Bass Gear
Yeah, I'm not surprised to hear that. Mike answers his emails when there is a chance he might actually make a sale of a preamp. To ship a single pot to Poland will cost him a lot more time and aggravation than it's worth. You can also see if Noll has any of these pots, he appears to get all of his stuff from Vlado Hansal. The Warwick website also used to sell them directly. Have you tried spraying the pot with DeOxit?
Yes, I tried but it did not help. The pot is from a bass that spent few hours under water during a local flood. The bass can be easily fixed (just few minor problems) but the preamp didn't survive it. Take a look at one of vias on the PC board.
I'd like to try to fix it. And to do it, I need the pot. I think that all problems with the board can be fixed. If I fail, I'll buy new modules from Mike. But it's not nice of him that he doesn't care for his customers .
Mark
