30-year project almost done, but not quite - problem with neos?
So, I made a very similar pickup, which I assume is what I talked to Mark about (don't actually remember!), and I also ran into a similar problem. This was for a 5 string Moses Graphite bass, and the pickup was cast in a mold of the original pickup (After belt sanding the top off the original pickup to determine how it was made). After it was done the G string was way too quiet.
I figured that after the pickup was wound and encapsulated, the G string magnet came loose and moved closer to the D string.
So for the next pickup, I made a wooden core to hold the magnets in place.
Here you see the original pickup, made on thin PCB, the spacer, and the second pickup which I made with fiberboard.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Thanks Mark. It's ironic since it got embedded in epoxy, never to be seen again!It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by SpareRibs View PostHello,
Some of those earlier pickups were made with the type of magnetic material refrigerator magnets are made from. That could be used for the bottom flat work.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David Schwab View PostRubber magnets are too flexible to use as flatwork. The kind used for refrigerator magnets don't have a regular N & S pole... they are in alternating strips. So they aren't suitable for pickups. Rickenbacker uses rubber magnets. They are very weak and create muddy sounding pickups. For such a shallow pickup, thin neos are perfect.
-rbDON'T FEED THE TROLLS!
Originally posted by rjb View PostSome DeArmond pickups used a rubber magnet glued to a steel backplate. The backplate was the lower flange; the upper flange was two sheets of plastic (similar to that used for acoustic guitar pickguards) laminated and glued on top of the magnet.
-rbIt would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
