DiMarios 80s Any made with none hex poles, blank, slot type dia.? Re Kay K45 guitar
  • DiMarios 80s Any made with none hex poles, blank, slot type dia.? Re Kay K45 guitar
    I bought a Kay K45 rifle guitar/Austin hatchet made only in 1981 travel guitar that are ostensibly DiMarzios.
    No stamped logo, brass plate but threads stripped on adjuster holes.
ID:	871381Click image for larger version
ID:	871382Click image for larger version
ID:	871383Click image for larger version
    There were many DiMarzio copies back in the 80s. It was common to see lots of Asian guitars with DiMarzio looking pickups, both with hex poles and not. Even Schaller made their own clones.
    I have a few of them in my parts box.
      Hi David,
      Thanks.
      So, of unknown quality, copied cosmetically only?
      Everyone listing these at £2-400 confidently claims that they are DM's!
      Cheers
        The quality is probably good. I have one of those mounted in a guitar I built. It's probably from one of the Korean makers.
        If they were DiMarzio it would have their name on the bottom.
          Really, specifically from a Kay K40? or would it be the only copy available?
          K40 was built in Cort factory.
          I thought pups in copies of that era were the weak point.
          Thanks
            zedax, those depicted p'ups are *not* DMZ.
            They're cheap, OEM, asian origin p'ups.
            You can easily spot'em due to that horrible colored, extremely high capacitance lead coming out.
            And the model made with two slug bobbins were the cheapest of'em all.
            Sorry to be the bearer of bad news.
            HTH,
            Pepe aka Lt. Kojak
            Milano, Italy
              Thanks. I had concluded the same but when confronted with so many listings purporting they are DMs I consulted the oracle.
              I think it is down to the colour.
              However, I read an article that maintained that any functioning pup has appreciable merits, depending on taste.
              Cheers
                DON'T FEED THE TROLLS!
                  Blocked for NBC Universal copyright reasons, so, we will never know why you posted it?
                    Well anybody can say anything in an article, and they often do! But this statement reminds me of a quote that was attributed to Nile Rodgers: "never get rid of any reverb." No matter how trashy. I guess you could say the same for pickups, speakers, amps, etc. If you have the room to keep it, also keep in your memory where you have it, something that sounds "off" might just be the hook that makes your next recording a hit.
                    Then the trouble starts: you have to perfectly replicate it every day on your worldwide concert tour.
                      Hi, It's only a pup, one factor in a long chain from string to ears with numerous ways of processing it in between.
                      One man's "off" is another man's on, though I do recognise consensus of opinion, but also advertising, product reinforcement, endorsements, peer pressure, gullibility etc.
                      I prefer alnico Celestion speakers and yet some seek JBL 120s which to my ears are harsh, sterile and pingy.
                      I somehow prefer SD alnico pups but I have not researched each type or option using an AB comparison with the many variables I refer to above.
                      I ended up with a rig that had a fault that I was not aware of which along with a roller saddle trem. that robbed me of sustain that I didn't recognise.
                      I developed a style that compensated with more and cleaner notes.
                      That's probably relates to Ywingie endorsing low output pups.
                        Bummer. Where are you? No blocking issues here.
                        Unfortunately, it's one of those "you have to see it", "picture is worth a thousand words" dealies.
                        A verbal description could never be as eloquent.
                        Nonetheless:
                        As cows graze in the background, Jack White partially drives three ~16d nails into a ~2-1/2 ft length of crusty old warped 2x4. He strings some bailing wire between the terminal nails, and jams an empty Coke bottle under the wire at one end- the third nail blocking the bottle from sliding toward center. At about midpoint, he secures a ~6" length of 1x4 pine with two brads at diagonal corners. To this riser, he loosely attaches what appears to be a cheap Tele bridge pup (with conveniently pre-attached output jack pigtail) by tacking it down with a single nail driven through a mounting hole in the bottom flange. He plugs into an amp and plays some uber-raunchy riffage- using a Craftsman spark plug socket as a slide, natch. Upon completion of scaring the cattle, he breaks the third wall to inquire "Who says you need to buy a guitar".
                        Get it?
                        -rb
                          You didn't miss a thing, 1:37 minutes, I'll never get back.
                          Too bad it wasn't blocked here!
                          T
                          Terry
                            Too bad it wasn't blocked here! T
                            Terry I hope you'll risk another couple minutes for a new post on your "covers" thread. No fence posts, no wire, just a little fun. http://music-electronics-forum.com/t26810-5/#post449396
                              I don't know anything about your pickup, but I do clearly remember in the 80s, Cort LP style guitars advertised in the Sears catalog with "super distortion pickups" They had all blank slugs and double cream bobbins. Dimarzio?
                              Vote like your future depends on it.
