Originally posted by Fuzzdemon
View Post
Potentiometers always have static scratching noise
Originally posted by 52 Bill View PostThe pedal sweep is controlled mainly by the taper of the wah pot. Original pots in the '60s were very fast in tonal sweep, which contributed to their vocal phrasing sound. Through the years with different manufacturers, the tapers started to change and now pots are available in a number of different tapers, none of which have been documented of compared, as far as I know of, at least.
Original pots had a reverse audio taper. To get a wider tonal range, I'd suggest that you try and find a pot with a linear taper.
I will look out for linear taper then thanks.
Originally posted by eschertron View PostI think you're still missing a Tesla coil and a couple Jacob's ladders
Just half-kidding. If you're aiming for laboratory gear, I say go for it! If you want something gig-able, take Nick's advice and scale back. I have a hard time coordinating standing up and playing; just thinking about tweaking half a dozen knobs and switches during a performance makes me dizzy
Originally posted by nickb View PostHere's another approach I just thought of.
If it's just the bottom end you don't like you can reduce the range of the wah by adding a resistor ( or pot) between ground and pin 1 of the the wah pot to avoid the bassy end that you don't like. The value of the WAH pot is not shown (100k?) so I suggest a pot wired as a variable resistor of half of the value of the WAH pot would be suitable. You can then tweak to get the desired range.
I don't think the pot you heard of would have a longer travel. Probably different taper like 52Bill mentioned.
A longer travel pot would require a longer rack and maybe even a deeper cutaway for the heel to rock back further.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by Enzo View PostOr a pot gear with fewer teeth, so each inch of rack travel turned the pot shaft more.Last edited by Fuzzdemon; 04-01-2017, 01:46 PM.
dunlop 1990 pot - 124k
hot potz 2 - 104k
chase tone pro 100k - 96k
Im gonna play around and see what happens when I add resistors like you suggested, I cant believe it didnt occur to me to use the MM on the wah pot already.
