Test for Sidewinders
  • Test for Sidewinders
    Folks -
    I recently had occasion to prescribe a test for possible mis-wiring of encased sidewinders, which produced an unexpected benefit.
    As suspected, the yanking of a ferrous hunk of something away from the sides while measuring a series connection and watching for similar ohmmeter response from both is a good way to determine proper relative polarity. However, I also discovered that it's a good way to see how much subtractive effect between coils (as in stacked configurations) exists. If you just read one coil and yank away from each side you can see how much opposite polarity influence there is on the combined system. Each coil will produce a significant deflection of the ohmmeter needle (for the recommended analog meter) when the ferrous material is yanked away from that coil's side. However, it will also produce a lesser deflection of opposite disposition when yanking the metal away from the opposite side. It's instructive to remember (as is the case with simple stacked coil arrangements) that this "subtractive" influence exists in the combined output of both coils.
    Bob Palmieri
    The Seth Lover humbucker patent included a sidewinder configuration.
    It employed two short, offset coils- I believe, to minimize this subtractive coupling effect.
    -rb
    DON'T FEED THE TROLLS!
      -rb
      Yeah... this common axis (and common core, commonly) is also likely responsible for the fact that the total inductance is less than the sum of its parts (those of the individual coils.)
        So a sidewinder is essentially somewhat inefficient, not unlike a stacked coil configuration?
          I say yes
            Narrow aperture sidewinders with magnets in the coils work great.
            Shielding foil helps keep them quiet.
            T
              Agreed. Keeping permeable material out of the cores minimizes hum.
              I'm a bit of a shielding but, and that definitely helps keep out buzz.
                Yes, but they are more efficient than stacked pickups. One of my first sidewinders started out as a stacked pickup. It was thin sounding with not much output as a stack, but sounded much better turned 90°.
                  Bill Lawrence made sidewinders with air coils for acoustic guitars.
                    Yup. Come to think of it, that might be the way I first tried this, by turning a Duncan Strat Stack sideways....
                      Never tried (or saw) one of those.
                        I believe it was this pickup.
                        https://reverb.com/item/546950-vinta...p-the-silencer
                          Some more info here:
                          https://books.google.com/books?id=hf...0coils&f=false
Name:	Screenshot 2017-04-10 19.40.22.png
ID:	845259Click image for larger version
Name:	Screenshot 2017-04-10 19.40.30.png
                            [ATTACH=CONFIG]43155[/ATTACH]
                            Oh yeah... THAT one! I have seen those, just bought one for the files!
                            Thanks, David!
