Gold Foil Bobbins
original bobbins were nylon and very thin so they flair really easily and they often come warped even before you wind them so you have to straighten them- you either have to have a tailstock winder or make a caul to squeeze both sides of the bobbin and then you have to really be mindful of tension setting on the coil wire. Unless you spend a bunch of $ on making an injection mould you have to build them up which is possible but not easy- thats how anyone would make prototypes. Its a somewhat tedious pickup to make- every part has to fit exactly in order to assemble correctly. Not the most difficult but certainly harder to make than most pickup typical designs.
Originally posted by Lollar Jason View Postoriginal bobbins were nylon and very thin so they flair really easily and they often come warped even before you wind them so you have to straighten them- you either have to have a tailstock winder or make a caul to squeeze both sides of the bobbin and then you have to really be mindful of tension setting on the coil wire. Unless you spend a bunch of $ on making an injection mould you have to build them up which is possible but not easy- thats how anyone would make prototypes. Its a somewhat tedious pickup to make- every part has to fit exactly in order to assemble correctly. Not the most difficult but certainly harder to make than most pickup typical designs.
I've got 6 different materials to try. I will not be paying for an injection mould for these anytime soon.
Three ideas come to mind. Not sure how practical though. ALL need a winding face plate that covers the bobbin width & length with a matching tailstock plate on a tailstock winder.
1) Make faceplates out of metal so the pressure will remain on the coil when removed from the winder with two machine screws through the face plate which can be installed before the bobbin is wound (machine screws through the plates in the center of the coil, with tapped metal faceplates to accept machine screws). Make the bobbin using card stock or plastic sheets and a plastic or wooden core. Take faceplates/bobbin and wax pot as a complete assembly, separate the faceplates after the unit has cooled using an "acoustic bridge removal knife".
2) Use faceplates as described out of metal as above with a tailstock winder. Use card stock and wooden core to make the bobbin. Use a bondable wire.
3) Use faceplates as described out of metal as above with a tailstock winder. Use card stock and wooden core to make the bobbin. Use tape on each side of the bobbin flanges and fold the tape over on itself after winding while still mounted on the winder.
My two cents. Always practice safety first when winding or coming up with creative solutions to problems.Last edited by Jim Darr; 06-10-2017, 10:39 PM.=============================================
Keep Winding...Keep Playing!!!
Jim
Originally posted by Jim Darr View PostThree ideas come to mind. Not sure how practical though. ALL need a winding face plate that covers the bobbin width & length with a matching tailstock plate on a tailstock winder.
But I think the only way to do this, having done some prototyping this far, is to integrate the magnet into the bobbin. That's not how these were done originally, but...
So the magnet becomes the core. Once wound the coil may need to be epoxied while still between the winding plates or perhaps just have some wax applied (basted in wax) to keep it from flaring out of control.
#1 Would be impracticable in removing the faceplates & wound bobbin from the winder as a unit. Also, you would have to clean the wax off the faceplates really thoroughly and completely after each bobbin is wound. Any chunk, piece, or drip of wax remaining would have to be removed from the faceplates completely. Also, the subsequent bobbins wound might be off if the faceplates were mounted is a slightly different position. This option would be tedious, time consuming, and frustrating. I DO not recommend this as a viable option.
#2 Having an extra type of wire, bondable, would be an added expense and create more unnecessary inventory. Plus you would have the get the bonding agent as well. Not recommended.
#3 This, I think, would work, even with the magnet as the core as jrdamien suggested, and prevent flaring.=============================================
Jim
Originally posted by Jim Darr View PostUpon further thought I would dismiss #1 and #2.
On making the bobbin:
How thick is the original plastic?
:wild speculation:
It looks like it would be fairly easy to vacuum-form from nylon or some other thermoplastic.
Your buck would be a piece of wood or mdf of core thickness, with a rounded rectangle cut out in the middle.
(EDIT: No, the buck should be the rounded rectangle - "positive" vs "negative".)
You could probably make one with multiple rectangles, to form several assemblies at once.
Cut your pieces to size, then glue or thermally bond the center to a flat sheet of same size.*
Your bobbin will have a wall that covers one side of the core opening. Would that be a problem?
Insert a piece of wood, plastic, or metal in the core, to reinforce it during winding (this could possibly be part of your winding faceplate).
After winding, stabilize "somehow" (see Jim Darr's suggestions) and remove the core reinforcement.
* Finding the right adhesive or bonding technique might be the hardest part. Here are some suggestions for nylon.
Bonding Nylon | Industrial Adhesives | Polyamide Surface Preparation
:/wild speculation:
-rbLast edited by rjb; 06-12-2017, 04:11 PM.DON'T FEED THE TROLLS!
Good point. You could wind the coil directly around the magnet- and that appears to be the way they were originally made:
Gold Foil Guitar Pickups Japan...Types & Observations | eBay
But I think fiber flatwork would be considerably thicker than the original bobbin flanges.
FWIW, I have a "toaster-like" DeArmond pickup. The bottom "bobbin flange" is the flat, enamel-painted steel baseplate, and the top flange is two sheets of plastic laminated together - thin black plastic that looks like the stuff acoustic guitar pickguards are made of.
-rbLast edited by rjb; 06-13-2017, 06:43 AM.DON'T FEED THE TROLLS!
