Originally posted by Leo_Gnardo
View Post
Marshall Major Blowing Power Fuse
Originally posted by cluster View PostThanks for that tip. Just to confirm what you said: lift the hockey pucks off the chassis and measure resistance to ground from each pin 3 ??? what should I be looking for as far as resistance? If I read 0 from pin 3 to ground, then there is a short in the OT?? Is that what you mean? thanks
If that doesn't show any difference there's still the possibility of a short thru a tube socket. To test this you'll have to unsolder the OT primary leads from the suspect sockets, just a little more work than unbolting those resistors.
If you still have a short to ground after having done these, there's no choice left, the short must be internal to the OT, and that will be a costly pain in the neck to replace. It would be a double disaster if you replaced the transformer only to find the short was thru a socket or SG resistor.This isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostThere are taps on your OT primary, each goes to a pair of those hockey puck resistors. So - if a short developed thru that resistor to chassis, you would see the resistance to ground readings you are getting. It's an easy exercise to unbolt the suspect resistors & pop them off the chassis. If your short or near-short reading changes to open then you know where the problem is.
Why lift anything? You have about 30 ohms through the winding. One end is grounded, and it makes sense the other end then shows 30 ohms. You have screen taps? FIne, measure resistance to pins 4 of each socket. I bet you find the value of the resistor plus the transformer resistance. Lift the zero ohms end wire from the socket. Still shorted?
Also a good possibility instead of shorting directly to ground, your primary may be shorted to secondary. Secondary resistance is usually VERY low normally.Education is what you're left with after you have forgotten what you have learned.
Originally posted by cluster View PostSo once I lift these hockey pucks off the chassis and read the resistance to ground at pin 3 and see "OPEN" then that means that there is a short to ground at one of these pucks? Is that correct? Thanks again for your generous help :-)
FWIW in the Major I worked on a couple weeks ago, there was already one output tube socket replaced. I retubed it, sent it out - with a 6 amp fuse that ought to be enough. Sure thing the fuse blew when the owner started pushing his amp hard. One of the new output tubes shorted and its socket was covered with arc debris so I replaced that too. Was it the socket or the tube? Chicken & egg question. I wasn't about to risk another tube so replaced its crusty burnt socket too.This isn't the future I signed up for.
Raised the hockey pucks off the chassis and measured the resistance on the leads of the ultra-linear taps. Left side 9.2 ohms to ground. Right side 20.7 ohms to ground. Left pin 3 is still 0 ohms and the right pin 3 is 29.5 ohms to ground. Not getting a good feeling here. Next is to disconnect the the primaries at pin 3 to see if there is a short in the tube socket.
On a side note, I'm sourcing an OT just in case. Here are 3 choices;
TAD at 279 euros ( $311) plus shipping: Output transf. for Marshall Major 200 W Ultralinear - Output Transf.
Banzai Music at 154 euros ($171) plus: https://www.banzaimusic.com/Transformer-T-OP-M200A.html
Or Mercury at a wapping $446: http://www.mercurymagnetics.com/imag...TC-MMAJ-OA.pdf
Any experience with TAD or Banzai?
Those readings simply verify the zero ohm end is shorted to ground or secondary. the taps are mid-resistances that fit right into the scenario.Education is what you're left with after you have forgotten what you have learned.
Since it looks like the transformer might be bad, we are at the what is there to lose stage. Note carefully where they all go, and disconnect all the secondary wires. Is pin 3 still shorted to ground? If so, the primary is shorted to frame (most likely). If the short went away, then the short was to secondary.
So pull the transformer, and CAREFULLY cut into the fish paper or whatever surrounds the windings. Look for the points where the winding wires are bonded to the insulated wires that leave the transformer. Is it possible somehow that joint is touching and could be corrected?Education is what you're left with after you have forgotten what you have learned.
Bad news. De-soldered the primaries at pin 3 (left and right) as well as the CT. Tubes sockets are fine (no short to ground at pin 3). One side of the primary is still 0 ohms to ground, so it seems like there is a short from one side of the OT to the frame/chassis. Next step is to do what Enzo said. This will be a pain since I will need to de-solder the secondaries at the Christmas tree stand-off array at the top of the chassis. Keep you posted. This amp was made in 1970 and it took 47 years to blow this OT. Hopefully, i will able to fix it and keep it original otherwise a new OT will be put in. Either way, it was sad prying apart those primaries that were stuck together with some kind of wax.
Originally posted by cluster View PostRaised the hockey pucks off the chassis and measured the resistance on the leads of the ultra-linear taps. Left side 9.2 ohms to ground. Right side 20.7 ohms to ground. Left pin 3 is still 0 ohms and the right pin 3 is 29.5 ohms to ground. Not getting a good feeling here. Next is to disconnect the the primaries at pin 3 to see if there is a short in the tube socket.
Mercury is a ripoff IMO and banzai is far away so no need to have it shipped overseas.
Originally posted by nsubulysses View PostThere are two places that would probalby do it cheaper or same price as banzai. Magnetic Components (chicago) and Heyboer (Michigain). They will make whatever you want. Heyboer has no product line and only does custom transformers. Magnetic Components product line is Classic Tone but they will also make whatever you want.
Originally posted by Enzo View Posttake notes take notes take notes... never rely on memory or "I'll figure it out" to get wires back where they belong.
