Now with more snarl and 400% more aggression!
Yup, Another One... Kraken 50 Build: Round II
I thought they were Kraken eggs...
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Something shameful that needs to be hidden? Or is there some functionality that the wrap serves?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostSomething shameful that needs to be hidden? Or is there some functionality that the wrap serves?Last edited by FourT6and2; 07-29-2017, 02:31 AM.
Oh, dude (not Dude, with a capital D. I'm talking to you, FourT6and2)... Hey, I just got it! 46 & 2, like our chromosomes
It only took me 3 months to crack the case and actually read your name correctly. Don't I feel like a Tool!
(see what I did there, dropping the "Tool" reference in just for good measure)
Anyway, let me steer this back on the tracks. I noticed you gang up your ground terminals, so I thought maybe these may make you life a little easier. I use them to fasten grounds at the filter nodes and love'em. I've been to give you the heads up about these solder terminals if you're interested:
Newark has these as an example:
19.05.745 - ETTINGER - SOLDER EYELET, 3X ANGLED, 0.169" | Newark element14
I got mine from through ebay, shipped from Israel and remember them being inexpensive.
But, the holy grail of ground terminals still evades me. For the life of me, I don't know where the hell Morgan Jones got his hands on these –
But, I can't find these anywhere, and I'm pretty good at sourcing components. Much better than I am at reading comprehension when it comes to people's names.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Stacking lugs on a bolt is questionable, specialy when we talk about signal returns due to unavoidable mechanical contact residual resistance. I made myself multipole lugs whenever I need it from a piece a plumbing copper pipe. Cut it on lengh, plane straighten, and cut out with a scissor how many pole you want, staining at the end. It takes ten minutes to made a couple if you design a good template.
There are some "tricks" to make a easy soldering multipole lug. I make the section of the base of each lug as small to limit the thermal transfer from the top of the lug to the rest of the piece.Last edited by catalin gramada; 08-05-2017, 11:24 AM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostStacking lugs on a bolt is questionable, specialy when we talk about signal returns due to unavoidable mechanical contact residual resistance. I made myself multipole lugs whenever I need it from a piece a plumbing copper pipe. Cut it on lengh, plane straighten, and cut out with a scissor how many pole you want, staining at the end. It takes ten minutes to made a couple if you design a good template.
There are some "tricks" to make a easy soldering multipole lug. I make the section of the base of each lug as small to limit the thermal transfer from the top of the lug to the rest of the piece.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Nice work. I would recommend moving the center tap of your 2x 350V secondary over to the HT PCB. Specifically the negative terminal of the first filter cap, right after the rectifiers. There are exactly zero good reasons to have the ripple current from the HT supply flow through the chassis. Make the HT supply PCB be completely 'floating', then route ground and HT to the rest of the amp.
Originally posted by mikepukmel View PostCatalin, if you stack them, can you clean off one side of the stack and use a heavy 100W soldering iron and put a bead of solder down to the chassis to get rid of the additional resistance? Ive been scouring the web for photos of vintage chassis like the one Im working on, and I don't know if its factory, or later changes, but many of the chassis with lugs bolted to the chassis have had the lug soldered. Is there any reason for not doing that?"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
