I hear all the time that Brand X vacuum tubes sound way better than Brand Y vacuum tubes. I have never heard anybody say that Brand A transistors sound way better than Brand B transistors.
Do different brands of transistors sound different?
sure can be a problem if they're counterfeit."Stand back, I'm holding a calculator." - chinrest
They don't sound any different, in principle.
HOWEVER, different brands of the same numbered transistor, and even different batches of the same numbered transistor from the same manufacturer (brand) CAN result in a different sound in the same circuit, simply because they have different specs, such as hfe. That said, the question is why would they "sound different"? And the answer is that the components around the transistor are predicated on the transistor having certain specs. Changing those surrounding components to compensate for those transistor specs can result in the identical "sound" across different transistor batches and makes.
It's a bit like asking "What colour is the brightest?". The answer will depend on what the background is. In the case of transistors, the "background" is whatever components are used to bias the transistor and set its gain, in addition to supply voltage, etc.
Originally posted by darkfenriz View PostTransistor are too cheap right now for anyone to have business in making the effort in such claims.This isn't the future I signed up for.
Originally posted by Axtman View PostI hear all the time that Brand X vacuum tubes sound way better than Brand Y vacuum tubes.
On the other hand, we know there are always manufacturing tolerances to deal with - if you pick up ten 12AX7s from the same manufacturer, each of the twenty triodes will have slightly different transconductance, anode resistance, and gain. If you happen to stick a higher-gain triode in the same circuit, it will distort more. If you stick a lower gain triode in, it will be distort less. Depending on your taste, you may then decide that one of them sounds better than the other. And then you might notice that the one you happened to like better says "Mullard" on it, and draw the wrong conclusion - that all Mullard 12AX7s sound better than all Brand Y 12AX7s.
So I've always wondered if these differences people say they hear between brand X and brand Y valves, really come down to nothing more than normal minor variations due to manufacturing tolerances, and are not due to brand difference at all. I might be lynched for actually coming out and saying that on a forum, though.
Originally posted by Axtman View PostI have never heard anybody say that Brand A transistors sound way better than Brand B transistors.
When it comes to transistors, there is something beyond superstition to consider, though. The very oldest and most primitive transistor circuits were very sensitive to normal manufacturing variations in transistor parameters. This is a very bad thing for mass-production, so smart engineers got to work, and figured out how to design solid-state circuits that were very robust to changes in transistor parameters. Negative feedback is one of the elements that make this possible, but circuit topology is also involved.
The end result is that a properly designed (and properly used) solid-state amplifier will behave almost exactly the same whatever transistor you use (as long as the transistor can actually handle the voltage, current, power, and frequency demands placed on it). That, of course, means that it will also sound the same whatever transistor you use.
As usual, there is an exception - it lies in the two words "properly used" in the preceding paragraph. In music electronics, we sometimes do things that fall outside the bounds of proper use. Overdriving the heck out of an op-amp is an example - they were never designed to do this, and therefore, some will overdrive more gracefully than others.
One last thing to keep in mind - we are very fallible creatures. If we pay more for a valve, or transistor, or car, or loudspeaker, we will automatically hear/feel/see that it is better than the cheaper alternatives. This is why very few Yugo owners would refuse an even swap to a Mercedes, even if it turns out that that particular Mercedes model was a lemon.
-Gnobuddy
Wait a second -- if silicon all sounds the same, then where does Tube Screamer mojo come from ?!?!
Originally posted by bob p View PostWait a second -- if silicon all sounds the same, then where does Tube Screamer mojo come from ?!?!
(And my daddy is bigger than your daddy, too!)
-Gnobuddy
my previous post was a reference to the Op-Amp Mojo attributed to the Tube Screamers that contain the "magic" JRC4558. there are guys that are so hung up on Op-Amp Mojo that they rip apart Japanese electronics looking for an original vintage JRC4558. RG's even written a tech paper on this.
The Technology of the Tube Screamer
Me? Never owned one, never built one. But if you believe the lore, the Mojo comes from the Op-Amp. Or maybe it's the magic clipping diodes ... I'm surprised that nobody has recommended using FRED instead of signal diodes for smoother tone ..."Stand back, I'm holding a calculator." - chinrest
Originally posted by bob p View PostMe? Never owned one, never built one. But if you believe the lore, the Mojo comes from the Op-Amp.
In my twenties, however, I did build several diode-clipping circuits of my own design, as well as a variety of transistor clipping circuits. I eventually gave up when I realized that I really didn't like the sound of any diode-clipper thingy I could devise.
Years later, I stumbled across the fact that following a diode-clipping circuit with a dollop of delay, and maybe a sprinkle of reverb, can take most of the ugliness away.
A few superhuman guitarists - David Gilmour, Eric Johnson, and maybe one or two others - have managed to create truly beautiful sounds from diode-clipping circuits. All of them seem to have used a stew of multiple other signal-processing ingredients to transform harsh diode clipping into something beautiful and ethereal. I've tried once or twice, but never managed to duplicate their magic myself.
Here is a rare case of Joe Bonamassa not suffering from his usual frantic widdly-widdlies, and actually slowing down long enough to showcase some really lovely "50-lb violin" tone: https://www.youtube.com/watch?v=iChc...ABE54DAE4C1802
I have no idea what Bonamassa was using to create that tone, though.
Originally posted by bob p View Post... I'm surprised that nobody has recommended using FRED instead of signal diodes for smoother tone ...
My suspicion is that most all diode-thingies will sound about the same, minor differences in low-pass filtering aside, as they all have the same logarithmic transfer function. MOSFETs and JFETs do sound distinctively different than the various diode clippers, which isn't too surprising. To my ears, they generally produce less harshness.
The mystery, to me, is that an unwanted and unloved NOS $1 TV valve will so often end up sounding better when overdriven, than anything solid-state.
-Gnobuddy
Gilmour uses a wide variety of effects, and pretty much all of them set quite low. Low gain, high volume, big amp in a big room, little amp in a little room. Real acoustic feedback is a major ingredient in his sound, which I find much cleaner than many most of the time, since Wish You Were Here. But he's the only one I know anything about.
I think the "sound" that most of us are really chasing is something largely out of reach, due to grumpy neighbors, families, and friendly neighborhood law enforcement... But I keep on trying, anyway; sucks to the neighbors!
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
