Between the can capacitors there is a resistor that doesn't look like any other resistor in the whole circuit.Can you tell what type of resistor this is,I am fairly new to all this .Do you know if the old color band codes from the 1960s ,match today's color codes .Green as hell,but I love learning interesting stuff .I would appreciate any info.thank you very much
Can anyone identify this supposed 1960s resistor between the can capacitors
Very old resistors have a color code that works in the sequence 'body-tip-spot'.
Explained here:
https://www.vintage-radio.com/repair...resistors.html
Colored bands do work the same as today's.
I'd guess 1k, if I can read the paint correctly... what's it measure?
Maybe 1W...
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
The smaller carbon resistor is easy: red-red-red = 2.2K +/-20%
I assume the larger resistor follows the body-tip-spot code that malcolm referenced in post #2.
On my screen (which has lousy color rendering), I see a red body and a black stripe = two-zero-some number of zeroes.
Is there a hidden dot somewhere on that resistor?
-rbDON'T FEED THE TROLLS!
