I am replacing the power cord on an old Bronson guitar amp. I want to run the hot side fuse to switch to primary, and the neutral straight to the other side of primary. Right now it has the switch and fuse on opposite sides of the primary. Problem is, I have nowhere to tie the neutral down, except pin 6 of one of the 6V6s that is going unused. Is there any harm or risk in this? I don't want to use a wire nut.
using unused socket lugs
No, PLEASE do not do that.
As suggested above, a simple butt splice, whether a crimped connection or soldered with heat shrink or tape.
Or mount a small terminal strip under a transformer bolt or other screw to provide a solder terminal.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostOr mount a small terminal strip under a transformer bolt or other screw to provide a solder terminal.This isn't the future I signed up for.
We call that a pigtail splice. Both wires come in the same end. The butt splice is the one where the wires come in opposite ends. Other than convenience in a particular case, I consider them equivalent. The pigtail requires one crimp, while the butt splice requires two, but really, that is a matter of a couple seconds. The pigtail does have the advantage you can combine the wires and solder as Mick describes and use the crimp as merely an insulated cover. Also with the proper size splice chosen you can splice more than two wires in one thing. Butt splices are pretty much one wire to one wire. If you have one extra wire, you can crimp a splicer on the end to insulate it, and lash it to other wires.Education is what you're left with after you have forgotten what you have learned.
I find I get a better and more secure crimp connection when crimping non soldered wires. But, The closed end connectors are a great suggestion.
If I’m updating an older amp wirh a polarity switch, Ill use one side of the switch as a conveniet terminal to join the wires.
Since the cap gets removed, the switch serves no fuction in the amp other than maintaining the original aesthetic.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Originally posted by Randall View PostEnlighten me on the particulars of a Bronson amp? It's my first.If it still won't get loud enough, it's probably broken. - Steve Conner
Thanx Dave H for the Death Wish film poster JPEG. Crikeys that was nearly 50 years ago, seems like yesterday!This isn't the future I signed up for.
Originally posted by Dave H View PostI don't think the wires are supposed to be soldered (or tinned) when using crimp connectors. The solder can 'flow' over time and the crimp become loose.
