Page 5 of 5 FirstFirst 12345
Results 141 to 152 of 152
Thread: Safe to put V1a coupling capacitor on a switch for variety?
  1. #141
    Aug 2012
    Great Black Swamp
    1,775
    Received: 19/0
    Given: 61/1
    If I was a betting man, I'd "bet a packzi to a donut" that the low-ish impedance at the cathode means less hum introduced there than you imagine.
    Distortion is a form of signal degradation. It is pretty easy to define what a good "clean" signal is, but trying to achieve just the right kind of "broken" can be pretty maddening. - glebert
  2. #142
    Supporting Member
    Jul 2017
    74
    I broke 1 of the 9 loop and it brought the noise down to 19mV from 27mV..... That was the only one that was an easy break, but yeah, looks like I need to rewire these switches like I should have in the first place.
    Edit..Inverting all switches made it worse. But only by a tiny amount. However, it brought the hiss down so it's still a net gain in reduction.
    What's a good target level in mV at the tap with both gain and volume maxed on a high gain 4 stage like this?
  3. #143
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,218
    Received: 178/0
    Given: 251/0
    Quote Originally Posted by Mr. Bill View Post
    This seems odd. The impedance at that circuit is very low and hiss is typically a byproduct of gain relative to Johnson noise (thermal noise) which is a byproduct of circuit resistance. I can't think of anything about the cathode circuits that should change the hiss level noticeably. I fear something you've done has reduced gain or your testing was done in two different gain modes. That is, I don't think you've actually lowered hiss unless you've lowered gain because that's impossible (though there are exceptions that don't apply here).
    "I'm just going to perform a bit more scientific investigation, turn it up to 11 and rip of the knob." überfuzz
    "If you build it, it will hum..." Justin Thomas
  4. #144
    May 2007
    pacific north west
    13,218
    Received: 178/0
    Given: 251/0
    They're all different due to grounding scheme limitations. And how can differentiate between hum and hiss just reading AC noise on the output? I can only tell you that with that many stages maxed there should be so much hiss that hum is a moot point That's not necessarily a bad thing, it's just the brakes. I have my own amp open on the bench right now, but it's not a high gain preamp type amp. It's an overdrive the piss out of the power tubes amp and it's only 17 watts. Still... Two stages into a third that boosts to OD the PI that is already ODing the power tubes, so, five stages with the last three clipping. I'll go take a measurement and we can adjust for wattage Be back in a bit.
  5. #145
    May 2007
    pacific north west
    13,218
    Received: 178/0
    Given: 251/0
    I have 46mV of hash on my output with the tone stack pots at 5, presence 0 and the volume dimed. Note the presence setting!!! And that 46mV is for a 17W amp. I consider this entirely acceptible. Of course, since I'm dimed and I have no no master volume this is measured with the power amp wide open. Not sure if you're testing like this. At these settings my amps gain is in pseudo metal territory. Probably not dissimilar from yours.
  6. #146
    Supporting Member
    Jul 2017
    74
    With presence and all tone controls at noon with both gain and volume dimed I'm getting 134mV at 100 watts.
    Will draw schematic to help investigate how hiss was reduced. Total noise came down by about 10mV.
  7. #147
    May 2007
    pacific north west
    13,218
    Received: 178/0
    Given: 251/0
    We're actually ham handing this. That mV indication is meaningless without knowing the load, so... I'm using an 8 ohm load. So that's .000265-ish watts of noise And by your numbers, unless you're using a very low load, I would think you've done better considering it's a 100W amp.
  8. #148
    Supporting Member
    Jul 2017
    74
    8 ohms That rogue wire trick of yours shaved off another 10 or so!
    Here's how the switches were wired before.
Name:	Ground Switch.png
    Side note. Since elevating the filaments, the amp makes a couple quiet pops while warming up, then never again. Is this maybe something to do with the elevation? Perhaps my larger than needed cap value?
  9. #149
    May 2007
    pacific north west
    13,218
    Received: 178/0
    Given: 251/0
    Perhaps. If noise goes up when you lower it to 22uf, just bump it back up to 100uf (it'll be as quiet at 330uf fo reals) and since there's no significant current through the circuit regularly it shouldn't matter at all when using the amp other than those little noises at startup.
  10. #150
    Supporting Member
    Jul 2017
    74
    Popping was cathode follower slowly frying a tube that was good a few days ago. It was getting worse and I tracked it down. Hum with gain off / volume max is now down to 10mV with a gain max / vol max noise level of ~129mV. I kinda think I'm reaching an apex here of as good as it's going to get.
  11. #151
    Feb 2010
    9,926
    Received: 123/0
    Given: 281/0
    Some tubes (brands) are not happy in cathode follower positions due to heater to cathode voltages. You may have to get picky for that spot.
  12. #152
    May 2007
    pacific north west
    13,218
    Received: 178/0
    Given: 251/0
    He means Russian tubes Not all of them, but many. I use Shuguangs (China) in CF's.
  1. Coupling capacitor voltage rating - Calculating the 'proper' value?
    By exclamationmark in forum Theory & Design
    Last Post: 05-25-2015, 03:47 AM
  2. Where to put Standby switch?
    By Q delorenzis in forum Guitar Amps
    Last Post: 11-26-2010, 02:13 AM
  3. Strange coupling capacitor problem
    By shzmm in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-06-2009, 03:31 PM
  4. Resistor Safeguards Leaky Coupling Capacitor?
    By tbryanh in forum Theory & Design
    Last Post: 04-18-2007, 11:09 AM
  5. Coupling Capacitor Leakage Current?
    Last Post: 04-13-2007, 01:29 AM
